1990 FLHTC rear master cylinder
Old Oct 11, 2007 | 08:36 PM
Team Flash's Avatar
Team Flash
Default 1990 FLHTC rear master cylinder
I have replaced the rear brake light switch on my bike but I cannot locate the master cylinder. Can someone tell me where they hid the darn thing. Thanks
Old Oct 11, 2007 | 09:28 PM
daven9113's Avatar
daven9113
Default RE: 1990 FLHTC rear master cylinder
Team Flash,
Rear brake master cyclinder is located on the right side bottom frame rail, between motor and tranny. Can't miss it.
dave
Old Oct 11, 2007 | 10:12 PM
paco's Avatar
paco
The reservoir for the fluid is behind door no 1 ! seriously it is behind the left side cover. right above the cb fuses and solid state elect block.
steve
Old Oct 12, 2007 | 05:35 AM
notlost_nc's Avatar
notlost_nc
ORIGINAL: daven9113
Team Flash,
dave
Hopefully he wasn't looking too long.
Old Oct 12, 2007 | 05:53 PM
Team Flash's Avatar
Team Flash
Thanks for the info it was the reservoir I was looking for and found. Thanks
Old Jul 10, 2013 | 11:18 AM
Mustangs4ever's Avatar
Mustangs4ever
Stage I
I have a 1990 FLHTC with a rear brake problem. When the bike is hot, and only then, I'm feeling a brake drag and what feels like a hard brake pedal. Initially I thought it might be the caliper hanging up by a cocked piston or something of that order, but that wouldn't seem to jibe with the "only when it's hot" part. My thinking is now the master cylinder at the foot pedal in that it catches engine heat and possibly something's going on there. This is all original equipment, and other than rear pads, no maintenance has ever been needed. I'm not one to just start changing parts till I get it right, so I'm wondering if anyone here has had a similar situation or has heard of one.
Old Jul 10, 2013 | 11:51 AM
Dr.Hess's Avatar
Dr.Hess
Make sure the pedal is adjusted correctly. If it isn't, it can interfere with the fluid return.
Old Jul 10, 2013 | 02:48 PM
04sportster04's Avatar
04sportster04
My 94 was doing the same and it turned out to be the caliper and old parts on the rest of the system. The piston was cocking as you mentioned plus my lines were in very bad shape.
I had my guy replace it all but the resevoir and now I'm happier. New lines, caliper, even switch.
I am a preventive maintenance kind of guy plus I'm keeping the bike. I love my carb on my 1994 FLHTCU. EVO all the way :-)
Old Jul 10, 2013 | 02:58 PM
Dr.Hess's Avatar
Dr.Hess
Also make sure no one put DoT 3, 4 or 5.1 fluid in there. You never know about DPO's.
Old Jul 10, 2013 | 08:59 PM
Gunslingertom's Avatar
Gunslingertom
Rebuild the caliper, master cylinder, flush the reservoir and install a new brake line. Fixed. I'm saying the brake line lining is swelling up and keeping the brake fluid from returning to the reservoir. Happens when the brake lines get old. I put a braided line on mine. Should last the rest of my life. All parts available from your local HD parts counter or Dennis Kirk.
juco
Ironhead
Aug 7, 2017 05:48 AM
Stampy167
EVO
35
Jul 16, 2015 08:29 AM
katanaplanet
Oct 26, 2014 07:49 PM
d-streetglidr
Aug 8, 2013 06:22 AM
Jeff2002WS6
Aug 15, 2012 11:07 AM
