Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Steering head adj.
Old 12-11-2017, 07:47 PM
Kaycee's Avatar
Kaycee
Kaycee is offline
Default Steering head adj.
05 Wideglide doing the fall away test I get 1" of fall on left side and 4.5" on the right ,I loosen stem nut and get 0 on left and 3 .5 on right. Went by the service man. clutch cable removed and all electrical harness' =no binding. Seems no matter what I do it never evens out. Lost at what else to look for
Old 12-13-2017, 06:05 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Could be the head bearings are pitted. Worth considering replacing them.
Old 12-13-2017, 09:26 AM
Kaycee's Avatar
Kaycee
Kaycee is offline
10-4 am planning on that , I may just try and grease them for now and see if it cures it. Can a guy just drop them enough to grease with the needle on the grease gun.?
Old 12-13-2017, 09:48 AM
grbrown's Avatar
grbrown
grbrown is offline
You can do, but there is quite a bit to do so you can. I've never tried that, on the few occasions I've serviced head bearings I've replaced them and made a clean start.
Old 12-13-2017, 05:47 PM
Kaycee's Avatar
Kaycee
Kaycee is offline
After tearing it apart today I came to the same conclusion what PITA this is getting to be . Guess Ill take it in to work and torch the bottom stem bearing off do I need to press that 1 back on also ? Manual says to cut cage and take the rollers out and heat race it will fall off, so that means the new bearing will not just slide on right.
Just Me
2014-2023 Touring Models
26
03-04-2018 10:58 AM
hogbag07
11-12-2012 07:21 PM
All Aces
08-20-2010 09:35 AM
StevenL
General Topics/Tech Tips
09-05-2008 12:12 AM
skykingFLHTCU
07-13-2008 08:53 AM
Quick Reply: Steering head adj.
