Heim Joint
Heim Joint
Adding Heim bearing to shocks, Does anyone have a parts source for this. Ohlins has then on their shocks. I would like to add them to Bitubo shocks. All i have is AllBallsRacing for a parts source. and one suspension shop near me. I can press the joint into the shock end and i need is a source. I will measure and give my info to the shop. thanks TonyD
I would not use those bearings. They are high speed bearings, static load sucks.
You want something like these..
https://midwestcontrol.com/shop/COMP...cal%20bearings
https://www.mcmaster.com/spherical-bearings
