I have a '02 Road King Classic that I purchased last fall with only 5,000 miles on it. The rear air shocks will not hold air. I'm looking for a fix or a solution to my problems. Thanks in advance for your help.
If you can't visually see any oil from the shock itself then it would stand to reason there is a leak in the air lines/fitting some where...
If you want to lose the air lines altogether get some shreader air fittings and install 2 in the shocks and bypass the shocks altogether...
paul
