Fender alternatives
I can not answer your question if it would fit. But I did have a similar situation with my back fender had to move my rear fender struts to the outside of my frame on my 73 to accommodate the lowering.. the stock fender was not wide enough to go over the rear tire and no longer fit the struts. The local shop I used had some fenders and called me in to look at what they had.. They had a dyna glide fender the fit over rear tire and now fit the wider fender strut mounts. So I would say if you don't find a response here check your local shops they may have something lying around.
