Stainless hardware and nylocks
Old 02-21-2016, 10:48 AM
Stevos50nuts's Avatar
Stevos50nuts
Stevos50nuts is offline
Default Stainless hardware and nylocks
So this has happened to me multiple times and gets me so pissed. Working on my bike and mount something with a Ss bolt and nylock. Starts getting hard to turn wrenches....that's when I start trying to reverse it out and it just locks up solid. I've had to either snapped the bolt by torquing the **** out of it or last night I had to slice nuts in half with grinder. Am I dealing with cheap China hardware or what? I'm to the point now that I'm overly cautious when using them.
Old 02-21-2016, 10:59 AM
QC's Avatar
QC
QC is offline
Received 19,788 Likes on 9,863 Posts
Must be cheap hardware. I can't remember the last time I had that problem.
Old 02-21-2016, 11:12 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,998 Likes on 17,504 Posts
Cheap hardware, a lot of the import crap uses 303 stainless that tends to be soft and will gall up the threads. Check the specs before buying you want 18-8 or 316 grade when dealing with stainless fasteners. Oh and don't over torque, strong arming is the number one bolt killer.
Old 02-21-2016, 11:16 AM
WP50's Avatar
WP50
WP50 is offline
Received 1,720 Likes on 1,169 Posts
I haven't had this happen in a long long time.
When it did I had gotten the wrong nuts and the tread pitch and size were just a little off.
Was trying to put a 8mm metric nut on an 5/16 SAE bolt.
WP
Old 02-21-2016, 11:21 AM
CVO SG's Avatar
CVO SG
CVO SG is offline
Put a few drops of oil or grease on the bolt. Lube goes along way when using SS on SS. SS galls up real easy when heat is present. Just the friction of a nut spun on threads can cause it. As TB said, don't over torque. Once the threads are deformed the slightest, its all over.
Use 303 SS everyday, no problem. Lube!
Old 02-21-2016, 11:25 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
316 ss bolts, locks, and nuts with some lube, no more probs .
Old 02-21-2016, 01:42 PM
Stevos50nuts
Good lookin out guys. Thanks. No more going at it dry....lubricate
No worse momentum crusher like having to cut off a bolt you just put on around painted parts. FML
Old 02-21-2016, 02:08 PM
TwiZted Biker
Yup , the dremel tool has gotten a work out a time or two.......
Old 02-21-2016, 03:02 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,116 Likes on 492 Posts
Smaller bolts (1/4" & under) you can usually get by without lube stainless on stainless, if you use hand tools. Anything bigger gets dicey depending on thread class. The threads will "cold" weld themselves and there is no way to save them at that point.
Drop by your local Fastenal or similar fastener supply company and they can set you up with the correct lube.
We build equipment that uses lots of stainless fasteners. Sometimes we have the supply house provide pre-lubed fasteners, especially if they are going to be installed with power tools.
Old 02-21-2016, 03:11 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,410 Likes on 5,442 Posts
Used to build equipment with all stainless fasteners, and it is very common for them to do that, even with quality fasteners. I never put together stainless with out anti-seize.
Quick Reply: Stainless hardware and nylocks
