When Are The 2018 Models Being Announced?
#31
Link please if you have it.
Fixed it fer ya
#32
Received 4,386 Likes
#33
Received 19,733 Likes
#35
Received 14,179 Likes
#37
Having only recently moved to Harley Davidson bikes I can suggest three areas for improvement.
1. Weight, 800lbs is silly, if not embarrassing and I only have a Road King!
2. Heat, this M8 is as hot as the 103 I had for a few months
3. Wind management, for all this touting as touring bikes wind management sure sucked
#38
Received 3,389 Likes
#39
Actually, why did you even buy a harley? If you wanted all those things, probably should of gone with another brand or at least another model.
My local dealer in Vancouver, BC said the 3rd week of August they will come in.
#40
put an air compressor in one saddlebag, tool kit, tie downs;
any thing else you can think of if it is more weight you want....
2. heat: you can buy more restrictive mufflers to get the heat up to the
level you seek. Could also de-tune to make the engine run more
lean thereby generating more heat..........
3. wind: pull off windshield and install scoops to direct airflow on you.
These upgrades should solve your problems.............
