Two up riding, what to expect?
#31
As others have said, with the added passenger weight, remember to increase your stopping distance.
For smooth stops with a passenger, I do the majority of stopping with the front brake, then use rear brake for final stopping. This eliminates the last second front end dive you might experience when coming to a complete stop with the front brake.
Check out these tips from the MSF: file:///C:/Users/x0234762/AppData/Local/Microsoft/Windows/INetCache/IE/ZMZ9OVQ0/Passenger_Tip_Sheet.pdf
#32
#33
Yes in crease the shock spring tension .on your trip if the suspension "bottoms " the shocks reaches the end of travel . Then increase the pre load 1 turn . Keep doing this till the shocks don't bottom for 95% of the trip . When solo readjust you shock pre load
Fully loaded 2 up on a 14000 mile trip to Anchorage <br/>
#35
walc
10-07-2007 07:28 PM
