easy way to get the oil out of your filter with out mess
Hi,
I just found a amazing product by no mess products in Florida. Buy this product and get a 3/8 hose and take a drill or impact drill with a 14mm socket and screw it in on the low point of the filter. Takes all of the oil out if the filter without a mess! I included a photo of the product and if you would like one they are $20 at https://www.nomessproducts.com. you can also you this for your car or truck too!
I have my bike on the side stand........small drip pan under filter draining into pan on floor.....drill hole in said filter........drain oil.....unscrew oilless filter
Just use a piece of cardboard or aluminum to guide the oil into your drain pan. Seriously, you're going to spend plenty on your bike buying **** you actually need.
17mm socket to remove the PCS4C oil filter, dump out oil filter in to oil drain pan; clean filter element with brake cleaner, wipe down the billet housing with a paper towel; mount filter back on relocation. Done. No drama, no mess
I'm usually not one for gadgets, but I had some "Harley Bucks" to spend and I bought one of their orange filter drains. What a great, but very simple idea. I wish I had bought one years ago.
I remove the voltage regulator first(2 nuts) that makes it easier to remove the filter and use the cardboard or foil to drain.
