What's wrong with the twin cam engine?
Old 10-23-2018, 02:39 PM
Stud Duck's Avatar
Stud Duck
Stud Duck is offline
Originally Posted by Raider Bill
My 03 TC has over 160k on it with no problems other than maintenance
Did you switch out to gear drive cams?
Old 10-23-2018, 02:44 PM
hd4evr2008's Avatar
hd4evr2008
hd4evr2008 is offline
Received 1,850 Likes on 833 Posts
It's not "motor". It's "engine". A motor runs on electricity. No biggy.
The following 4 users liked this post by hd4evr2008:
fsae0607 (10-24-2018), heavyd1 (10-25-2018), Jehu (05-01-2020), Mountainkowboy (04-30-2020)
Old 10-23-2018, 02:51 PM
BTLorys's Avatar
BTLorys
BTLorys is offline
Received 2,664 Likes on 1,231 Posts
Better tell the "MoCo" to start calling itself an "EnCo"
The following 5 users liked this post by BTLorys:
Fritz1218 (09-02-2023), motorbtr (01-29-2024), Rogerio (12-18-2021), Superdog3:16 (05-02-2020), Trask (05-01-2020)
Old 10-23-2018, 02:54 PM
soldierbot's Avatar
soldierbot
soldierbot is offline
POD Squad
Received 92,510 Likes on 23,795 Posts
Gotta take my enginecycle in for a tuneup.
Hmmm...Enginecycle just doesn't sound quite right.
The following 5 users liked this post by soldierbot:
Harfar (05-01-2020), Rains2much (07-18-2023), Rogerio (12-18-2021), Slowrider63 (04-30-2020), Trask (05-01-2020)
Old 10-23-2018, 02:56 PM
dixonk's Avatar
dixonk
dixonk is offline
Received 7,508 Likes on 3,579 Posts
What's wrong with it is that it's not an EVO!
The following 8 users liked this post by dixonk:
bentparts (10-24-2018), Buddy7394 (07-19-2023), fsae0607 (10-24-2018), hvacgaspiping (10-30-2018), Mountainkowboy (04-30-2020), Paintslinger16 (10-23-2018), RANGER73 (05-01-2020), Uncle G. (10-23-2018) and 3 others liked this post. (Show less...)
Old 10-23-2018, 03:00 PM
0maha's Avatar
0maha
0maha is offline
Received 4,669 Likes on 1,661 Posts
Originally Posted by Unclescarhead
I see a lot of you guys like to call the twin cam a twinkly. I was just wondering as a twin cam owner why some consider that particular motor to be no good.
"Twinkie" is just a word. I don't think of it a pejorative. Anyone who says twin cams are "no good" is talking out of his ***.
That said, for me, the Evo is the last of the proper HD engines. I think you can draw a straight line from the Knucklehead designed by Mr. Harley himself, straight through the Pans and Shovels, then into the Evo. The Evo can be reasonably described as a Knucklehead after 50 years of incremental refinement. They broke that line with the twin cam. They had their reasons (many of which were imposed by the EPA), but it is what it is.
The following 5 users liked this post by 0maha:
Durham man (10-27-2018), Fritz1218 (09-02-2023), hvacgaspiping (10-30-2018), Mountainkowboy (04-30-2020), Uncle G. (10-23-2018)
Old 10-23-2018, 03:09 PM
04Hali's Avatar
04Hali
04Hali is offline
It was actually supposed to be called the Fathead but that didn't catch on. Like the Evo being called a Blockhead.
Old 10-23-2018, 03:26 PM
1HOTTrain's Avatar
1HOTTrain
1HOTTrain is offline
Just the sumping issue .................. Oh wait my bad. Wrong engine
Old 10-23-2018, 03:32 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,608 Likes on 3,851 Posts
My 04 has 50K and all original. Runs and sounds like new. Other then alternator rotor stipped the spline from an abrupt stop from abuse, nothing has been changed on the motor. Sure if it was flogged as some people drive them, it would have problems by now. I am sure the cam chain tensioners should be replaced from age but they are not worn out. Primary is noisy from the chain having uneven wear that make odd uneven noise at idle but that hurts nothing. Done that since 20K when rotor stripped.
Old 10-23-2018, 03:46 PM
QNman's Avatar
QNman
QNman is offline
Received 3,713 Likes on 1,988 Posts
I'm on my third Twinkie.
My first (an 88 punched out to 95) was wonderful in the 650-lb Deuce frame. Had gear driven S&S cams, fully "stage IV' treatment, and made 100HP/100lb-ft at the rear wheel. Didn't burn or leak a drop of oil.
My second was a 2010 Limited with the non-HO 103. Once I got it properly tuned and the header de-catted, it ran much cooler. It wasn't a race bike, but it pulled adequately for a touring bike. Didn't burn or leak a drop of oil.
My current is a 2016 Road Glide with the HO 103. Noteably more agreeable than the 2010, even stock. Now, with cams, putting down 92HP/110lb-ft, it is a dream. At 22,000 miles, it doesn't burn or leak a drop of oil. Doesn't transfer oil, doesn't sump. Heat is still a little bit of an issue for the passenger on really hot days, but all in all.... I frickin' love this bike and have no desire to "upgrade" until this one is less fun.
crazytown (10-23-2018)
Quick Reply: What's wrong with the twin cam engine?
