Derby bolts and O-rings
Greetings all,
I am looking for opinions. I have a '17 Ultra Classic and took it in for its 10K check to Dealer X while I was on a road trip about 2K miles ago (3.5 months ago - yeah, I know, I'm not riding enough). A few weeks ago I noticed a leak. When I got to my local dealer, they discovered that three Derby cover bolts were missing and one was loose and the primary drain O-ring was loose. Every ride I take starts and ends with a mile on a dirt road. The local dealer says that there's no way that if these were properly reinstalled would they become loose. IMHO, Dealer X took a cavalier attitude when I called to inform them of what happened based on the subsequent local dealer involvement.
Curious about your take on this sitch?
Thanks.
Thanks.
tar_snake (12-12-2018)
Received 4,314 Likes
+1 with shoddy work by a shoddy tech, a traveler on the road needing a 10K service. It would not bother me to identify dealer X so that those on the road can avoid their "services". Three out of five screws backing out and being lost on the road, if the primary drain "o" ring was loose the plug wasn't far behind. The torx screws I have on my primarys have a split lock washer, if you don't trust those put a small dab of blue loc-tite on the threads. When I'm going to be on a lengthy trip I change oil and primary fluid prior to leaving, just in case. My '13 Roadie can go 5K (service interval) between oil changes. Don't know the dealer, sad they treated you like that.
Uncle Larry (11-09-2018)
Greetings all,
Thanks.
Thanks.
One last thing for what it's worth, if you need to have work done on your bike that you are not comfortable doing yourself, find a good Indy Mechanic. They are usually way cheaper than the Harley Dealers and their work is much better.
ole_phart (12-12-2018)
I had a buddy who left the dealership after having a rear tire put on . The "tech' didn't install the spacer on the left side of the wheel resulting in my friend not even making it to the highway (which is a good thing ). Destroyed all kinds of parts and could have killed him. I bought a new 12 streeglide and rode 22 miles home with 20 pounds of air in the tires and the oil in the transmission not even touching the dipstick. Lazy *** dealer is the problem here. They are quick to take your cash though.
My younger brother got his new bike back from the dealer with damage all over it, marks in the paint and even a dent in the front fender. They made it right and when he went to pick it up they had dented the tank. His rear wheel spokes loosed up on him and they trued the wheel and it happend again, they did it again and you guessed it, it got loose again. He cut ties and took t to a different dealer and it was fixed for good that time. This was done all under warrenty. I just hate the thought of leaving my bike at one of these places.
Moral of story is service manual and learn to use it.
