Took a look at cam tensioner today
Haak30 from OP
Thanks for the reply and picture. I was really hiping to hear from others exactly like that. Being that i am going to be pulling plate tonsee inside tensioner inam just going to replace. Probably replace with original as i will have the tools so i can go back in agter another 40k. As i am less than 2 years from retirment i hope that is sooner rather than later.
Was this with the newer hydraulic tensioners HD has used since '07?? I thought that problem was fixed with any bike newer than an '06.
You should also seriously consider some drop in cams while it’s apart. Just look at the reviews throughout the forums on Andrews 48H, those cams will wake up your stock 96 and put a smile on your face. You owe it to your motor to let it breathe!
Check Out Fuel Moto for Cam kits they come with the Torrington Bearings and new lifters as well. Do some homework and I’m sure you’ll find similar advice 100x over.
klap (03-12-2019)
Received 17,598 Likes
From the OP. Yes i was not very clear. So far the only OEM parts i am looking at are the shoes. I am upgrading the inner cam bearings as i ordered them and the tool from MBS manufacturing look to be the same as Heartland tools. Cams i am going to hold off on as i have only had this bike for 3 years and i said i would as a project keep it as stock as i can and see what happens. So for i have done wheel bearings and brake rotors as 2 out of 3 warped. I probably dont ride this bike hard enough to know if it has been woken up. I have a couple of other bikes i run a little harder.
Thanks for replying.
