Duel front discs for Dyna Switch Back 2014
Hi Guys, I customized my Dyna switchback by adding a number of body parts such as a fairing, rear luggage box basically turned the bike into a touring model.
I would like to fit duel discs to my front wheel. What do I need to do to make this happen.
Cheers
Cheers
The following 2 users liked this post by pgrchaplain:
fxdup (11-19-2019),
sonruss@62 (11-19-2019)
You need to check out the center to center of the fork tubes on a pre-2014 (2013 down to 2000) FLT than you will need to get another wheel. You are going to be challenged as the triple tree is not the same as I have a Switchback nacelle. The rest of the story gets much more complicated. Good luck and loose the meaning of the word easy.
Have you considered putting a larger rotor on to increase braking performance?
https://www.arlenness.com/prodcat/rotor14.asp
Pretty much as Carl mentions above ... FLD uses 41mm tubes
and same fork tube centers as "Touring" (9-7/8")
So use everything from Touring
*2000-13 sliders (41mm)
*2000-later Touring wheel, (change bearings, center spacer sleeve and add bearing shim as needed depending on what year the donor wheel is from)
*2008-later Touring wheel spacers
*2013-earlier Touring fender
*And of course ... appropriate Dual master cyl, brakelines, calipers, rotors, etc
Here's a look at a FLD frontend (happens to be on a FXD... doesn't matter) with everything stated above.
The Right Touring Slider has had the caliper mounts "Shaved", but they could have remained and been used the way you want.
https://www.hdforums.com/forum/dyna-...uperglide.html
