Tank wrap
Tank wrap
If you're doing it for some kind of advertising that's one thing but if you're wrapping it as a cheap alternative to a custom paint job it'll fail miserably. Wraps may not look too bad going by on a bus or a large truck but on a gas tank or fairing up close it looks cheap and low budget. At least I and most folks I know think so. But like everybody says, it's your bike.
wraps
Probably a disconnect between the kind of wrap you're talking about (clear paint protection film) and what Hey Man was talking about (a colored wrap to change the appearance of the bike).
wraps
If you're looking for cheap, scratch dipping off your options? Nevertheless the end results are amazing.
I've had a few bits dipped. Hydrographic 3D dipping is considerably more expensive than a simple paint job if you're changing the color? The base is still applied by traditional painting methods in the color of your choice, cured and then the transfer is applied by dipping. The transfer they apply still needs a decent base coat and lacquer top coat afterwards.
