How much better gas mileage using synthetic oils?
I'am trying to get my bike set up to get the best gas mileage possible. Considering it's a big Harley. Someguy's made the suggestion to use synthetic oils in it to get better gas mileage.
Just wondering if I switched to synthetic oils what I could expect?
Right now it's a totality stock new bike with 850 miles on it.
Thanks for all your help!!!
[IMG]local://upfiles/24160/F156145BCB92408280E20BD87BEB03D1.jpg[/IMG]
RE: How much better gas mileage using synthetic oils?
I think it is almost a wash with the added mileage to the extra cost of the oil, if you get 2 mpg more you will get 12 extra miles per tank, figure around ten tanks between oil changes = 120 extra miles or about 3 gallons of gas so figure a savings of $10 in gas per oil change.
I look at it the other way that the savings in mileage off-sets the cost of the synthetic oil from which you get smoother shifting, cooler running, quieter engine and longer engine life.
I've run synthetic in all my cars, pickups, and motorcycles for at least 15 years. I don't think you'll find that the increased gas mileage (and I think you'll need careful statistical analysis to see if there really IS any significant improvement) will make up for the increased cost.
What synthetic oil does best is to protect the engine against heat and startup wear. I've opened up engines with a lot of miles that used synthetic oil and found them to be clean as a whistle inside; that's not the case with engines running conventional oil.
Even at $4 per gallon, you'll not find that there's much out-of-pocket difference whether you get 40 mpg or 42 mpg.
In regards to mileage, I doubt there is a statistically noteworthy difference. The improvementswould be in decreasedengine/driveline wear and superior heat tolerance.
Engine wear and cooling are your main benefits. Any mileage gains are gravy.....
Check out the Amsoil site http://www.amsoil.com/ it is rated the best of all synthetics....
The site has all kinds of info to help you make a logical decision.
If you have questions or concerns..... email me @ 1amsoil@charter.net
I'm a dealer and proud of my product.
I sponsor my grandson's motocross team...
Stogie
Dealer # 1540076
Stogie
Dealer # 1540076
ORIGINAL: tattoo13
My 03 Heritage (with a carb) always got between 40-45 mpg. I changed to Amsoil in all 3 holes with about 11,500 miles on it. I now have about 13,500 and still get 40-45 mpg. One thing I DID NOTICE was that it shifted much nicer ....smoother quieter.
vanman59
Oil Archive (no new posts)
09-29-2006 11:44 PM
