What is my air cleaner?
I bought my 99 eglide from a guy that says he never modded anything on the bike. My air cleaner cover says "screamin eagle" on the outside and the paper element is a cone shape. Is this a factory set-up?
When I look in my service manual the element looks more like a flat kidney shape.
What gives here?
I want to replace my filter but how do I know what to get? Is this a K&N filter? There is no Harley shop here, can I get this at an auto parts store?
What gives here?
RE: What is my air cleaner?
Take the filter off and look on the inside... there will either be a K&N or Harley symbol and a stock number in there... sounds like a harley screamin' eagle stage one... change the filter to a K&N HD-0800 - you will be glad you did!
It's an improved breathing system... usually coupled with after market pipes... more air in - more air out. Does not necessarily mean that the carb was rejetted... check the bottom of the carb and see if the jet plug has been drilled out.
If the a/c cover is the stock football-shaped one and only the center ring says "Screaming Eagle" then the the air filter has been changed. The SE medallion comes with the Stage 1 upgrade kit from Harley, along with the SE filter and a Dynojet kit for the carb.
Snowman88
06-15-2019 01:45 PM
