too much oil in transmission?
RE: too much oil in transmission?
Yep, my manual says to check it on the jiffy stand. Remove threaded filler dipstick, wipe clean then reinsert and do not thread back in. Extract and check level.Pg.148.....
Well, that's at least one thing that'll be easier to do than the previous method! Thanks for the clarification.
I wonder how many people who have traded up for a new one have realized that change?
I have a question that most of you will call me a DS (take a guess). I just did my first tranny oil change with HD syn (in all 3 holes). My problem is I cannot tell the level on the dip stick (its the factory chrome one) ands its impossible to tell the oil level on the stick since the new oil is so clear and my eyes are so bad. Does anyone have a trick I can use? BTW, since it is probably still overfilled, I have a whining noise that is noticable around 20 mph and the noise decreases to 0 as the bike stops. This is new since I did the tranny oil change.
Received 4,366 Likes
I have found that if you wipe that dipstick dry and put it back in then when its pulled out if you hold the dipstick horizontally and rotate it just a little the light can show where the oil is or is not, yea it's a little difficult. Good luck.
1 Post
My manual calls for 20-24 oz. in the transmission and 32 oz. in the primary. For the transmission it should be checked with the bike in the upright position with the dipstick resting on the threads. For the primary, just pour 32 oz. into the primary and close it up.
You guys actually check it?
There is 32oz in a quart. Drain tranny completely, open a new bottle and pour the whole thing in, put the dipstick back in and go. I can't remember ever checking it but then again, I'm not too **** about the tranny. If there are no spots on the garage floor or under then vent tube, then it's still full.
I do use a measuring cup for the primary since it's a wierd amount on the 08. 38 oz if I remember correctly off the top of my head.
When you drained it, did you remember to get on the bike and hold it upright (even a touch past vertical to the right) to get the last few ounces out? Otherwise, you'll have enough left in there to show overfull when you fill it correctly with 24oz (32oz for six speed).
I've never bothered to check the oil levels. For a service I put a quart in both the primary and the gearbox and three quarts in the engine. I know the engine is slightly overfull but it's never blown anything out the breather or given any other problems. If there is no oil on my shed floor, I know there are no leaks.
