Yup
Originally Posted by *NIGHT TRAIN*
(Post 5680455)
I see you've got an '07 FXSTC...I've got an '07 Train...when I changed my rear pads, I didn't know what size that bolt was either...don't remember now, just that it was a standard size...
I do remember that I just slipped a few sockets on there till I found it...wasn't that big a deal... |
Originally Posted by *NIGHT TRAIN* http://images.ibsrv.net/ibsrv/res/sr...s/viewpost.gif I see you've got an '07 FXSTC...I've got an '07 Train...when I changed my rear pads, I didn't know what size that bolt was either...don't remember now, just that it was a standard size... I do remember that I just slipped a few sockets on there till I found it...wasn't that big a deal...
Originally Posted by bassgod806
(Post 5681543)
Good call :)
10 mm.
I see you never got an answer to your question?
My question is, why are you having to remove the caliper to remove the tire/wheel? You should be able to remove the axle shaft, belt, then ROLL the wheel and rotor out of your caliper. I have removed the rear wheel on my RK and my wife's Deluxe quite a few times this way never having removed the caliper. Sorry, I can't recall off the top of my head but I believe, as someone posted earlier, the caliper bolts are 10mm. |
Originally Posted by RoadKingRon1
(Post 5681662)
(Post 5681662)
I see you never got an answer to your question?......
He got the correct answer 5 times before your post. :) |
Originally Posted by Figstr
(Post 5683362)
The wheel won't move forward enough to remove the belt. The disk bottoms out into the brake assembly long before the belt gets loose enough to remove.
Originally Posted by Jim Dawson
(Post 5683579)
Never got an answer?
(Post 5679635)
I need to remove the rear brake (flat tire) and need a 12 point socket. What size is it?
© 2024 MH Sub I, LLC dba Internet Brands
