View Poll Results: What have U done to Ur motor
Voters: 139. You may not vote on this poll
I should fill up a page with things I done on the sig line. There goes a couple pages. I like doing engine rebuilts over a weekend. I need a real shop that tin shed is over rated for work.
103" Big Bore
S.E. 204 cams
Zippers open air filter
V&H Staggered S.S.
PCIII
Stock heads
Stock throttle body
Very well tuned
98.8 hp at 5500 rpm & 113.1 ft.lbs. at 4400 rpm
100 ft.lbs. at 2000 rpm
As said in an earlier post, this is where the perf. should be from the factory for the kind of money we spend on these bikes.
07' Train
S.E. 204 cams
V&H Staggered S.S.
PCIII
Stock heads
Stock throttle body
Very well tuned
07' Train
Yeppers I made a typo... Terry 155 is correcting it.........
spossed to read what have U done to ur motor........
1st mistake I've made since the last one........
Thanks for Ur answer....cause thats whats needed to make this a good poll...
SE Air Cleaner
SE Coil
SE Sparkplug wires
RB Racing LSR 2 into 1 header pipes
NRHS 1250 kit
Headwork is next but I will defer to the professionals for this engine upgrade.
SE Coil
SE Sparkplug wires
NRHS 1250 kit
