bad day my 2 year old 1500 dollar tv just broke! Now this dam clock!! I dont get this see how the black torx holding the clock is in the pic? Well the bolt on mine needs to be recessed I dont get this!!
Looks to me like you need to get a torx bit that has a small hole in the center that is made to accept the small ball in the center of the torx screw.The hole in the torx bit lets you get the bit in deep enough to remove the screw.Its there as a security measure [ unless the thief has the right bit ]. Most auto parts stores carry these type torx bits in a set.Good luck !
