Hand Levers
Has anyone replaced their clutch and brake levers with the chrome levers? How hard of a job is this? From what I've seen in the shop manual it pretty much looks like a easy swap out. Any tips or suggestions on how to go about this swap?
RE: Hand Levers
I've had them off my '98 FXDS and it's easy enough to do.
Removing clutch lever: 1. loosen the clutch cable 2. Remove the circlip from the bottom of the pivot pin (careful with this so you don't lose it) 3. pull the pin out 4. install is the opposite of removal Removing brake lever: 1. remove the circlip from the bottom of the pivot pin (careful with this so you don't lose it) 2. pull the pin out 3. install is the opposite of removal 4. stand back and enjoy what you've accomplished |
RE: Hand Levers
Yup, it's pretty easy just like RudeDog says. I have done mine without circlip pliers, but if you have pliers it's a piece of cake.
RE: Hand Levers
I ordered a set of black powdercoated levers for my Glide. Everyone said it would be easy. I was lazy, and when I took it in for it's 5k, I asked them if they would put them on. They did for no charge (5k was about $140, they put the levers on and put a new LED taillight in for free basically!)
RE: Hand Levers
Installed the new chrome hand levers this afternoon. A very easy project, probably took about half an hour if that. Wonder what the stealer would have charged to do that. How much labor time, hour or two?
RE: Hand Levers
Wow ,sounds pretty easy , I think I`ll give it a try .Always need more chrome !
RE: Hand Levers
The only thing to watch is the brake light switch. It is fairly easy to get it cocked inside the little rubber boot. You don't want that to happen.
RE: Hand Levers
I assume it's pretty easy. Once I tipped over my V-Rod and broke the clutch lever down so I only could fit a couple fingers on it. [:o] Hubby put a new one on for me and it was easy. Got a new bike and will be changing out the aluminum ones shortly! Definitely wouldn't take it to a stealership - they'd probably charge you an hour or two!
RE: Hand Levers
put some chrome trigger ones on a dyna, they look awesome. [sm=bling.gif]
RE: Hand Levers
LMAO :D the circle clip is called a snap ring, and you use snap ring pliers to take them off or put them on. if you have them it makes it alot easier.
Chris |
© 2024 MH Sub I, LLC dba Internet Brands
