Turn signal wiring question
Old 05-07-2010, 03:54 PM
Meat Head's Avatar
Meat Head
Meat Head is offline
Default Turn signal wiring question
Well I've decided to clean up the front end of my 2003 deuce. at this point I've put drag bars and braided lines on it. While doing the work, one of my factory front turn signals was damaged. I was actually considering eleminating my front turn signals anyway because it gives the bike a much cleaner look. However, I want to keep my rear signals for safty issues.
My question...............Will my rear turn signals work with the front disconected? Does the rear need the front to complete the circuit???
I'm hoping I can just tape up the front conection plug and the rear signals will continue to work.
Any input will be greatly appreciated! I don't want to put my gas tank and everything back together until I know the wiring is finished but I want to get my bike back on the road ASAP. Thanks in advance.
Old 05-07-2010, 04:30 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
I pulled the fronts off my Nighty, but put male/female insulated disconnects (females are on the hot leads, of course!) so I could slap them back on for the annual inspection without pulling the tank. The module that controls them seemed to take a couple seconds to "learn" what had happened, and has been happily working ever since.
Old 05-07-2010, 05:06 PM
Meat Head's Avatar
Meat Head
Thanks for the info, I didn't want to put my tank and fuel lines back on only to find my rear signals don't work without the front ones connected.
Old 05-07-2010, 05:11 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Without front turn signals how will people know when you are trying to make a turn !!!
Old 05-07-2010, 05:18 PM
Meat Head's Avatar
Meat Head
I'm leaving my rear signals on. The rear signals are a necesity to warn other drivers that I will be slowing to make a turn. I don't rely on my front signals for anything. I don't trust other drivers to see my front signals before I turn in front of them.
Old 05-07-2010, 05:42 PM
pococj's Avatar
pococj
pococj is offline
Probably the way we did it before the Gooberment Nannies mandated the electric signals - using your left arm.
Old 05-07-2010, 06:21 PM
Meat Head's Avatar
Meat Head
Anyone else have any input on the question at hand??
Old 05-07-2010, 09:07 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
They are required here, but been thinking about going to smaller after market item.
Old 05-08-2010, 01:52 PM
Meat Head's Avatar
Meat Head
Hasn't anyone else removed the front turn signals on their bike???
Old 05-09-2010, 05:56 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Not me, you need them to keep from getting flattened by the azzhats that drive here in the NY/NJ area. You could have a 120 db loudspeaker announcing which way you are going to turn and multiple lights on both ends of the bike and there will always be someone who says " I didn't see him" For me, I'll take the big flat pancake signals on the front of my Road King, better than nothing.
Quick Reply: Turn signal wiring question
