My horn fell off!!!
Old 09-20-2010, 05:41 PM
eddie eggs's Avatar
eddie eggs
eddie eggs is offline
Default My horn fell off!!!
Has this happened to anybody else here? On my '10 SG the rubber mounting vibration dampener came apart. This is the one that is between the horn and the mounting bracket. I got home and found my horn dangling by its wire. Glad I didn't lose it. Looked like the bond between the rubber and steel came apart. I'm sure it's a warantee covered part, but it certainly doesn't give me a warm fuzzy. I wonder if this piece was outsourced to China?
Old 09-20-2010, 05:48 PM
petemac's Avatar
petemac
petemac is offline
That blows! (Pun intended...)
Old 09-20-2010, 06:08 PM
doghair's Avatar
doghair
doghair is offline
It's an omen. Get a air horn.
Old 09-20-2010, 06:10 PM
PowerFactor's Avatar
PowerFactor
PowerFactor is offline
Yep! Same thing happened to me. It was probably a warrenty thing, but I just got another rubber bit and fixed it real quick.
Old 09-20-2010, 06:17 PM
schumacher's Avatar
schumacher
schumacher is offline
that means your Harley is running correctly
Old 09-20-2010, 06:23 PM
CR3999's Avatar
CR3999
CR3999 is offline
It happen once while riding in a group. The guy that was leading, his horn fell off and everyone started dodging that sucker. It's kinda funny now but at the time there were bikes all over the road tring to miss it.
Old 09-20-2010, 06:24 PM
Rick-e's Avatar
Rick-e
Rick-e is offline
I guess mine is too......Saturday, one of my front turn signals was hanging by the wire for a few miles :-o
Old 09-20-2010, 06:26 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,331 Likes on 5,426 Posts
Originally Posted by eddie eggs
My horn fell off!!
Watch for finger!
Old 09-20-2010, 06:43 PM
monstead's Avatar
monstead
monstead is offline
Location: Dallas, TX & Santa Fe, NM when I can find the time....
Happened to me once, my brother once and my riding buddy twice. All 3 of us run/ran the Howard's Hog Horns. All failures happened within a short time of original install and at the same spot...on the mounting bracket that attaches the 2 bugles. The part that broke was a cast aluminum bracket which also has a rubber gasket to dampen vibration. Appears, the cast aluminum/rubber gasket combo doesn't hold up well to the vibration of a Harley! Imagine that! You'd think Howard would come up with a more durable mounting bracket since I'm sure we're not the only ones with this problem considering our group is 0 for 3 with this particular mounting bracket. All 3 of us ride '09 FL's.
My brother and friend both recently ditched the HHH and went with a ProPad horn on their bikes. My friend replaced her's after the 2nd time her horn bracket broke...my brother finally replaced his after his HHH went completely kaput. I, still rock the HHH and will replace it with something else when/if it fails.
Old 09-20-2010, 08:20 PM
artz's Avatar
artz
artz is offline
when my horn fell off, that told me to check the nuts and bolts on the rest of the bike.
Alot of stuff was getting loose. Don't forget the blue loctite.
Quick Reply: My horn fell off!!!
