Strange noises
Strange noises
Took a trip to the Ozarks for a few days. Trailered it up behind 5th wheel (yes...trailered it. Took the dogs and OL)
Anyway when I first cranked it over, the tapping was pretty loud for a few seconds. It never happened before.
While riding, I am now noticing noises intermittently as if loose pea-sized gravel is kicking up under front fender. I've never heard any of these noises before.
Am I just paranoid or might I have an issue that needs a look?
Thats what it sounded like. I hope not. Under warranty, but still don't want to have to deal with the dealer warranty issues on that since I change my own fluids. I can just hear the conversation now.
Riding all through the Ozarks in mountains and towns. The gravel noise comes and goes on all of them.
Since it was not running and all the shaking up and down it may have forced the oil out and took a second to pump up the lifter. Remember when running the lifter only pumps up to remove all clearance. The valve spring overrides it. No big deal. The noise in the fender is gravel. Just kidding. Once you start listen for problems on a Harley your in trouble. Sort of like reading a medical book with a headache and stomach ache. Mine makes all kinds of noises, been doing it for 40K
as long as y0u keep receipts that documents fluid and filter and some kind of chronological diary as to maintenance as stated in the owners manual, the only conversation you should hear from the dealer is when to drop it off for diagnosis.
Received 4,342 Likes
I've heard if you tie down the bike on the trailer in gear the movement of the bike will work into the valve train and actually pump the oil out of the lifter/s. The other tinging sound could be just small gravel being tossed into the fender. You are running premium fuel , aren't you?
Thanks everyone for your help and suggestions. I have the answers and ANOTHER question that I likely already have the answer to but I will throw it out in the end...
Loud tapping - Exactly as you all have said and not a big deal.
Tinging noise - I took it to Rogers HD right at closing time and let the master tech go for a ride. He says the bike running too lean and with the hill climbs of the Ozarks that I don't get in Dallas, TX the engine is detonating. He suggested riding with RPMs higher in the range. Well that didn't work. I still get it on accellerating on a climb.
The Question:Is there any type of additive that I can run until I get that work done and how damaging to my engine is this to run for a couple more days???
I had the pinging as well- especially on hot days and the dealer is right- it's detonation. A set of Xied's from Nightrider.com cured it. Your fuel injection system is running lean in closed-loop mode- a common issue. Xied's richen the mix in closed-loop to eliminate the detonation. If you plan to keep the bike mainly stock (no more than slipons & an air cleaner) this should take care of it & it'll run you about $100. If you plan big mods a more expensive fuel management system may be in order...
