Minor SNAFU during dealer service
Old 05-23-2011, 06:28 PM
JR-Boston's Avatar
JR-Boston
JR-Boston is offline
Originally Posted by szurlo
... and I'll get a service manual and do the rest myself going forward. ...
Not for nothing, but I'd go with the express shipping on that manual!
JR
Old 05-23-2011, 06:52 PM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,055 Likes on 631 Posts
Originally Posted by JR-Boston
Not for nothing, but I'd go with the express shipping on that manual!JR
____________
Old 05-23-2011, 07:57 PM
leicafish's Avatar
leicafish
leicafish is offline
It is called racheting and it does happen on some cables.
Glad it got fixed.
Old 05-24-2011, 06:40 AM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Originally Posted by ONEDOWNAND5UP
I believe the new bikes have a teflon lined clutch cable and don't require lube..I will have to check.
Mark
+1, they specifically say not to lube the clutch cable. Just the lever pin. I'm leaning on the fact that they probably forgot to refill the primary. It would do just what you are describing.
Old 05-24-2011, 07:07 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
My 2011 HD Touring service manual says to lube the clutch cable with Harley Lube P/N 94968-09.
I experienced the same rachet feel after The 1K was done on mine.
After putting a few more miles on I adjusted the clutch and lubed the cable with Motion Pro cable lube.Now it's good.
Old 05-24-2011, 11:30 AM
oct1949's Avatar
oct1949
oct1949 is offline
Originally Posted by BLKBAGGER
I have heard that when you lube the new teflon cables they stick real bad. Do you have a teflon cable?
Anyone know what yr did they started using the teflon cables.???
Old 05-24-2011, 12:18 PM
Foodog's Avatar
Foodog
Foodog is offline
If the service department has seen the problem before when using a particular lubricant why in the world are they still using it? If there is even a remote possibility that it would cause a cable binding problem then it should be tossed out in favor of a lubricant not known to cause the problem. Seems there is a liability issue here that the dealer would try to avoid.
Old 05-24-2011, 12:24 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,225 Likes on 1,626 Posts
Glad they got you fixed-up quickly & I agree w/others on the BS flag. Bet they lubed the cable & probably replaced w/new one to correct their mistake...JMO.
Old 05-24-2011, 01:05 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
Like the others, I don't see how the cable could make it grab. It would have to be erratically changing lengths.
I've been riding the daylights out of my new new 2011 Road King and in 4 weeks I was due for my 1,000 mile service.
250 miles a week is riding the daylights out of it? I guess they don't make daylights like they used to.
Old 05-24-2011, 07:38 PM
nytryder's Avatar
nytryder
nytryder is offline
You win the prize. 09 and up require no lubrication. I'm thinkin maybe the shop should buy and install a new cable at no charge. From what I read that clutch cable is now junk.
Quick Reply: Minor SNAFU during dealer service
