S&S super E
Bout ready to give up on this carb and et a different type done every thing everyone has said and adjusted it like s&s says to do but it still stalls,when the bike is warmed up if i crack the throttle real fast the engine will die if i roll the throttle it's fine,if i leave the enricher on and crack th throttle it responds great ,I have check for leaks sprayed wd40 and no leaks this carb has done this from day and it was brand new
Bout ready to give up on this carb and get a different type done every thing everyone has said and adjusted it like s&s says to do but it still stalls,when the bike is warmed up if i crack the throttle real fast the engine will die if i roll the throttle it's fine,if i leave the enricher on and crack th throttle it responds great ,I have check for leaks sprayed wd40 and no leaks this carb has done this from day and it was brand new
Carburetors are like cooking rice to me, try though I have, I never get it quite right by myself.
I'm pretty fond of Edelbrock single, downdraft carbs. By myself, always had better luck w/ Zenith carbs but they aren't real popular & a buddy gave me good reason to try the Mikuni.
I had the exact issue with my sporty. Messed with it forever. Took it to my Indy shop and he said it was running really lean. I couldn't tell you specifically what jets he changed or what he changed them to, but it ran like a raped ape after that. Sorry I couldn't be more specific, but I do know that for someone who is experienced tuning S&S carbs, it should be a pretty simple fix.
Accel pump system isn't getting the gas to the port make sure the little check ball in the pump cover is free and doing it's job a really small bit of rust or crude is all it takes to wipe that one fuel will bypass back into the pump instead of out the throat port . I've had to file the end of the rods a bit to get the correct amount of throw for a full squirt on a few and make very sure you don't have a slight intake leak going on that will give the symptoms you describe also . Leave the main alone that doesn't come into play till 2500 to 2800 RPM anyway , turn your mixture screw a 1/4 turn to the fat side and try again .
TwiZted is spot on with his diagnosis. If you've adjusted the accel pump screw and got no joy, pull the accel pump cover and clean/check for debris.
Be careful not to lose the ball, spring and tear the diaphragm when you pull it apart.
Also when you re adjust the screw I suggest you turn it no more than 1/8 turn at a time. Adjust to rich first till you see a little black smoke when you crack the throttle hard, then turn it back till the smoke just goes away. At that point you should have a good setting.
update on S&S carb
I did notice that with the air cleaner off and ideling at about 1000 rpm if I crack the throttle real fast fuel spits out of the carb like it's blowing back
