Another reason why I gave up my "Beanie" lid
RE: Another reason why I gave up my "Beanie" lid
ORIGINAL: HD7585
Your kidding, Right
Your kidding, Right
ORIGINAL: DirtyDave
Everyone is missing my point.
A helment will not save your life.
I don't knock anyone who wants to wear a helment. It should be a choice.
DirtyDave,
"If your so set on helmets save lives, do you wear one when your in you cage? FACT- There are more head injuries in cage accidents then in motorcycle accidents. Every hard point in the cage is a spot to hit your head and any passenger during an accident. FACT - Every race car driver wears one, no matter the type of race."
Give the liberals maybe 20 years and believe me they'll come up with helmets being mandatory in cars too. The Nanny State never stops growing...
From one who was hit by a cager pulling out of a parking lot and went airborn, I didn't ride before the crash withoua helemt and I won't ride without it now. That said, I also willl not dog you about your choice to wear or not wear a helemt. Your life, your choice. I figure I only got one head with a brain and I'd like to keep it, such as it is. What we don't need are more laws saying we have to do this or that or Big Brother will get us.
I also agree with the suggestion to take a riders course. Money well spent
Ride safe
Bubba
Ride safe
Bubba
ORIGINAL: DirtyDave
Not at all. Riders get over confident because they believe they will. If they did save lifes then why can't we wear them in autos? It just big brother and the insurance companies that want control. The insurance compaines know that manditory helment use lowers the number of regested motorcycles and states that repeal a helment law will have a large increase of registared riders.
ORIGINAL: HD7585
Your kidding, Right
Your kidding, Right
ORIGINAL: DirtyDave
Then you should have no problem at all with your 13 year old son or daughter using a skid lid when riding behind you. I mean, why bother with a DOT or SNELL helmet, right? It's just a little extra styrofoam, right? Right?
<><Peace
<><Peace
It's a choice. Even though Pennsy is anow a freestate, I still wear one most times cause the wife busts my ***** about it and hell, it could hurt a whole lot less if I do have it on.
Make up your own mind, don't let the opinion of others do it for you.
From one who suffered a head injury due to a car wreck... I can onlywonder ifa helmet might have prevented some of the bs that screwed up several parts for the rest of my life... Given that thought,, I wouldn't ride the bike without one, even if I could. Better safer than sorrier...
So how do you feel about Seatbelt laws?????
ORIGINAL: DirtyDave
Becoming a better Rider might!
I do agree with your last statement.
ORIGINAL: IOMC Qball
but to be dot certified it's has to hold up to a minimum of the 14 lbs of pressure when applied.
S6.2.2 Apply a 10-pound (4.5 kg) static vertical load through the helmet's apex. Center the helmet laterally and seat it firmly on the reference headform according to its helmet positioning index. S6.2.3 Maintaining the load and position described in S6.2.2, draw a line (hereinafter referred to as ``test line') on the outer surface of the helmet coinciding with portions of the intersection of that service with the following planes
Dot and Snell certification is determined by the drop test.
Prior to this testing the helmet is subjected to one of several enviroments. (a) Ambient conditions. Expose to a temperature of 70 deg.F(21 deg.C) and a relative humidity of 50 percent for 12 hours. (b) Low temperature. Expose to a temperature of 14 deg.F(-10 deg.C) for 12 hours. (c) High temperature. Expose to a temperature of 122 deg.F(50 deg.C) for 12 hours. (d) Water immersion. Immerse in water at a temperature of 77 deg.F(25 deg.C) for 12 hours.
S7.1.2 Each helmet is impacted at four sites with two successive identical impacts at each site. Two of these sites are impacted upon a flat steel anvil and two upon a hemispherical steel anvil as specified in S7.1.10 and S7.1.11
S7.1.4 (a) The guided free fall drop height for the helmet and test headform combination onto the hemispherical anvil shall be such that the minimum impact speed is 17.1 feet/second (5.2 m/sec). The minimum drop height is 54.5 inches (138.4 cm).
In addition to the drop test a penetration test is done also.
S7.2.1 The penetration test is conducted by dropping the penetration test striker in guided free fall, with its axis aligned vertically, onto the outer surface of the complete helmet, when mounted as specified in S6.3, at any point above the test line, described in S6.2.3, except on a fastener or other rigid projection. S7.2.2 Two penetration blows are applied at least 3 inches (7.6 cm) apart, and at least 3 inches (7.6 cm) from the centers of any impacts applied during the impact attenuation test. S7.2.3 The application of the two penetration blows, specified in S7.2.2, starts at two minutes and is completed by four minutes, after removal of the helmet from the conditioning environment. S7.2.4 The height of the guided free fall is 118.1 inches (3 m), as measured from the striker point to the impact point on the outer surface of the test helmet. S7.2.5 The contactable surface of the penetration test headform is constructed of a metal or metallic alloy having a Brinell hardness number no greater than 55, which will permit ready detection should contact by the striker occur. The surface is refinished if necessary before each penetration test blow to permit detection of contact by the striker. S7.2.6 The weight of the penetration striker is 6 pounds, 10 ounces (3 kg). S7.2.7 The point of the striker has an included angle of 60 deg., a cone height of 1.5 inches (3.8 cm), a tip radius of 0.02 inch (standard 0.5 millimeter radius) and a minimum hardness of 60 Rockwell, C-scale. S7.2.8 The rigid mount for the penetration test headform is as described in S7.1.11.
This site has test results for different manufacturers helmets.
