Difference between 2 into 2 & 2 into 1
Old 01-10-2014, 07:46 PM
CaptainKirk's Avatar
CaptainKirk
CaptainKirk is offline
I can appreciate the 2:1 gains but I just can't deal with the unbalanced look on the back of a bagger. And a ghost pipe seems too obvious.
Old 01-10-2014, 08:30 PM
e3troy's Avatar
e3troy
e3troy is offline
I have a 2-1 big radius whereas a friend of mine has the 2-2 big radius. IMO, the 2-1 has a lower rumble at idle but tends to get higher pitch at higher RPMs. The 2-2 is generally louder at all RPMs but has an even tone throughout. Either way, I think they both look good; I just see fewer 2-1 big radius pipes on the road compared to the 2-2 version.
Old 01-10-2014, 09:14 PM
Wheels24's Avatar
Wheels24
Wheels24 is offline
Originally Posted by Ratbike_Mike
The 2:1 design is meant to provide greater low-end torque and a "throatier" sound, where the 2:2s typically have a crossover pipe to equalize pressure in order to achieve identical performance in both cylinders and increased HP at higher RPMs.
That said, I really think you need to make a lot of other engine mods & fine tuning to truly gain these advantages to any significantly noticeable degree. Short of that it's mostly a preference of looks.
...what Ratbike and BigJ said...spot on. Remember that overall HP/torque profiles are dependent on a lot of variables, with exhaust configuration/flow being only one variable. When it comes to exhaust, most people keep it simple and focus on either low-end torque (keep some back pressure) or high-end HP (jettison all baffles). But neither approach will do much without at least some intake/carb/fueling mod's to match.
I rarely ride my street bikes WFO for long periods of time (as opposed to my race bikes), so I keep some back pressure and enjoy the low-end torque at 'normal' street riding RPMs. Bub duals with crossover for me...
maverick2076
Rush Racing Products
12-17-2014 08:20 AM
89Speedy
08-22-2012 01:54 PM
FUEGO
08-22-2008 08:08 AM
AdrianVall
06-01-2008 09:57 PM
Ed45
Exhaust System Topics
10-25-2007 11:39 AM
Quick Reply: Difference between 2 into 2 & 2 into 1
