New Battery saves weight and massive C.C.A
Old 05-14-2014, 11:00 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,879 Likes on 4,705 Posts
I'm running the 620CCA Antigravity and love it so far been over a year now , standard or " Big Crank " AGM or gel bat's didn't last a year in my beast and struggled when they did turn it over .
Lithium batteries been around for a while , most choke at the price tag is all .....
did you see that video from Matt Hotch?
Old 05-14-2014, 11:22 PM
Fishrrman's Avatar
Fishrrman
Fishrrman is offline
$450 for a battery?
This is a joke, right?
Right....?
Old 05-15-2014, 12:02 AM
Fozzy4325's Avatar
Fozzy4325
Fozzy4325 is offline
Originally Posted by RHPAW
You still didn't answer my question.
You mention the Optimate charger...that's a plug-in-the-wall battery tender. What about the charging system in the bike? You know...the stator and solid state regulator?
Once again, can the OEM charging system, resident in the bike as it stands, supply the charging needs of this battery without stressing the system?
Once you start performance upgrades, you have to consider the remaining existing components that will be affected.
According to the company which i phoned they said yes
Old 05-15-2014, 12:11 AM
Zim's Avatar
Zim
Zim is offline
Like just about all the re-inventions of the wheel in the last thirty years..... No thanks.
Old 05-15-2014, 12:15 AM
dgdamore's Avatar
dgdamore
dgdamore is offline
I'll take one when mine takes a ****. I like hi-tech stuff.
Old 05-15-2014, 05:55 AM
maddawg57's Avatar
maddawg57
maddawg57 is offline
Default battery upgrade
Yes i will get one soon ,
beats being stuck out somewhere in bad weather or good,
dealing with replacing a dead battery in what may be unknown locations ,
don't need that nightmare ,been there several times
thousands in a bike few hundred in a battery to get me moving when i hit that start button,
Old 05-15-2014, 09:22 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Wait... Antigravity!!!!! Hell Yeah!!! I want one!!!!!
Old 05-15-2014, 09:43 AM
harleycharlie1992
they make a skateboard too!
Old 05-15-2014, 09:52 AM
mmancuso's Avatar
mmancuso
mmancuso is offline
A difference between the AGM and LI batteries is that while the LI has plenty of power for cranking, it also has a greater voltage drop while cranking than the AGM.
This may not be a problem for many, but my friend put an LI on his OL's Triglide. She always leaves her electronic trip gauge on remaining miles to go, but every time she starts her bike, it reverts to the odometer. I saw the same thing happening when my stock AGM was dying. The cranking gets the electrical system voltage below the threshold that many electronic items need to retain their variable settings, the same as disconnecting the battery for those items.
I now know that if I ever see that happening again, my battery is on its way out. My problem with the LI is that they're always that way!
Not a problem for many I'm sure, but a real nuisance for others.
Old 05-15-2014, 09:59 AM
tmilo1000's Avatar
tmilo1000
tmilo1000 is offline
My first OEM battery lasted almost 9 years, bought another OEM battery, cost was about $125. Can't justify the cost difference.
Quick Reply: New Battery saves weight and massive C.C.A
