Longer fork & lower weight = less stable/less safe ride?
3 is wrong... ill slip on my 300lb wr just as fast as i slip on my 550lb dyna. Weight has nothing to do with it... tires however do. If your bmw has battlewings then yes, those tires suck. They sucked on the wr, and they suck on the tiger(501/502).
If it were me id stop thinking about it and just ride what ever i feel like riding. If all you ride is 30 minutes max then why even ride? Go buy a honda grom...
a) my 15 minutes on the express lanes would translate into an hour on the regular lanes if I were in a car.
b) parking in DC is expensive, hard to get in/out of the garages, and some close early. why not slide your bike between cars in the metered spaces right in front of the building?
c) chicks love bikes, see evidence attached
I have a Buell Firebolt and an Electra Glide, two bikes of very different shape, wheelbase and c of g. They probably represent the extremes of the bikes I have owned, with the exception of a couple of trail bikes. We've also mentioned BMWs, of which more shortly.
The Buell has a very short wheelbase and a high c of g, my Glide has a long wheelbase and a low c of g. The Buell won an accolade here in the UK when it was announced as being the best handling bike of 2005 bar none, against Ducatis and all the Jap sports bikes. Other Harleys hardly set any standards of excellence for ride quality or handling, even though I love the silly things!
I suggest you completely ignore those mechanics - fortunately there are engineers like Erik Buell out there who know much better than they do! And Avon tyres are great, I have them on all three of my V-twins.
As for BMWs, their models routinely have a high c of g, because they have an odd idea about bike geometry. The c of g lies on a line between the point of contact of the rear tyre on the ground and the centre-line of the steering axis, which it intersects at right-angles. I'll leave you with that one......
I've recently been riding a rigid chopper with an 84" wheelbase but also a 250mm rear tire.
I'm not feeling the snakes on the road like the fat boy.
It's pointing to the skinny 15omm tire on the fat boy.
The BMW may have a better suspension but the chopper doesn't.
The BMW may also have a shorter wheelbase but the chopper doesn't.
That only leaves the rear tire width (170mm on the BMW, 250mm on the chopper, and only 150 on the fat boy).
Generally more rake(and trail) make the bike more stables but harder to turn.. It's one of the reasons why sport bikes have suck little rake/trail. They want to turn quickly. I have seen situations where the bike does become more unstable when rake was added.. But it's uncommon. I owned a CNC softail that I added 4 inch over forks to.. Bike was real stable.. Actually handled real well..
It really boils down to trail. If you rake trees, you loose trail, if you rake the frame you increase it.
Interesting theory about the low CG. The would not surprise me as part of the reason when some lower the back end (which should increase rake and trail), the bike becomes unstable.. I would also suspect that it's coupled with a weak chassis and/or loaded saddle bags.
This, put forks flush with triple clamps more straight line stability,lose turning,put forks up in triple clamps quicker turning less straight line stability,maybe some head shake.
Now you have a lovely new front tyre, check the condition of your rear and replace that as well, if it is old or close to the wear bars.
