exhaust sensor
exhaust sensor
Hello all,
the cable of the exhaust sensor is hanging loose...
it is the cable comming from the rear exhaust pipe end it is going to an black plastic connector. Now the connector should be attached to something but where...???
Anyone have an idea???
And if you do can you show me a picture??
Thanks in advance!
Thanks in advance!
Hello all,
Thanks in advance!
Thanks in advance!
If you don’t have a P/C or other add-on tuner then not sure why someone would disconnect part of the EFI system that works to hold tune.
Bob
