What Jack to buy?
You pretty much hit the nail on the head. J&S claims a 1 ton lifting capacity using their 6 ton bottle. Taking into consideration the laws of physics, ie., leverage versus fulcrum point, the J&S 6 ton bottle is more than adequate for lifting 1 ton, but equally adequate for smoothly lowering 1ton.
So!!! I've yet to buy a jack but the time is coming sooner than later. In all honesty, I hate spending 5/600 on a jack that I'll rarely use except for oil change and tire removal. With that said, my local Harley dealer has on in stock for $299.00.
It is an 1100 lb and while I know it is in no way made by HD it does sport the HD logos so I'll assume its made for HD by someone out there. I have points built up at the dealer so I can actually get for around $150.00 and since its from the
dealer I assume theres some type of warranty. The million dollar question is, do any of you here have one of these, and can vouch for the quality? Thanks.
This: https://www.harley-davidson.com/stor...e-service-lift
BTW Tincup, thats a fantastic looking 3 wheeler.
Jack
First off, if this topic belongs elsewhere, mods please move it.
So I'm looking to buy a jack for occasional use to replace a tire or other maintanance that requires both wheels off the ground. I've found this: https://www.ebay.com/itm/Motorcycle-...53.m1438.l2649
Not sure what everyones using but don't want to invest huge amount since it won't be used regularly. Any suggestions otherwise? Thanks.
