Difference between spring shock 54484-97 and 54485-97
Hi.
I have Softail Crossbones. I need to change front shock, according to parts catalog it uses 54484-97, but Softail Springer uses 54485-97. It seems it is the same shock.
I am able to get 54485-97 but not sure if it will fit my Crossbones.
Any help to be sure about fitment it is appreciated.
Thank you
Thank you
This! It is my understanding that the one with the decal is for the 21" wheel. The one without the decal is for the fat tire'd Classic springer. They are valved differently. Also, I believe the Classic one has a nub at the top, whereas the FX-style does not. Good way to tell them apart if someone removes the decal. When it comes to the Crossbones, here's the part number and exploded view to show the current part #.
So my question would be are they relatively interchangeable? I understand that the valving is different but will that effect the handling significantly. I have a FXFTS, forgot the last S on my last post. If I put a stuffer shock on it will there be a significant change? Problem is the heater shock is more available.
Just like our engines (Fuel, Air, Spark = BANG!) physics and personal preference trump part #s for me. If this wasn't true for much of the globe, no one would be modifying their HDs! Good luck with the search and I hope you find the perfect shock for YOU!
SapperNS (09-01-2022)
