View Poll Results: Should H-D sell a Screaming Eagle turbo Harley?
Yes
70.00%
No
30.00%
Voters: 10. You may not vote on this poll
Turbocharged Harley
turbo advise
I live up the street from Custom Works in Daytona and "Russ" the bike salesman, has a turbo softtail that runs excellent. I've been on poker runs and the like with him, and it seems very well mannered. They are great people and I'm sure he would point you in the right direction. customworksdaytona.com They have a top notch shop, but he will give advise without arm-twisting sales. Give him a call.
andygears
andygears
My continued advice would be to try something besides the Aerocharger. I think they are still in business. If you are looking for stuff to make a boat anchor from...the Aerocharger would make a good choice. If you want to drown-out some severe top-end noise....then get an Aerocharger. The rattling noise emitted from the variable vanes will definitely overcome any known Harley engine noise. I am pretty sure they finally gave up on the CV and include a Mikuni flat-slide in the kit now. The carburetor does nothing for that rattling though. I would suffer any minimal turbo lag rather than put up with the noise generated from the Aerocharger variable vane system. You can't hear it if it's out under the hood of a car, jet ski or snowmobile, but you can when it's right down there between your legs.
Hey there, ive been building my own kit for a while now, it has come up pretty nice looking and works well, the only problem i have come up with is that my engine case keeps filling up with oil and blowing the primary drive side seal out. once i sort that out it should all be good.
I made up my own manifold and exhaust pipe, had the turbo made up with carbon seals to run fuel through it, then had it all ceramic coated.
The heads i cut out heaps to lower the compression, which helped out heaps after poping the engine three times already during my R&D phase. I think they are about 89cc chambers now.
I'm using a HSR48 Mikuni carb, (which is probably a bit big).
Turbo is a Garrett T2 with carbon seals.
can't remember right now what ignition is in it but it has a setting to limit the advance to max of 23 degrees.
I run an electric oil scavenging pump after the turbo to return oil to the tank.
The Turbo is maybe just a bit big for the engine but it gives a really smooth power curve instead of boosing up and hitting out all at once. It'll get you white knuckled with dinner plate eyes though. I have no idea of the HP or TQ numbers but it scared the crap out of me at about 3/4 throttle. A mate rode it who rides a 80" dyna with nitrous, he was pretty impressed with it too.
I got alot of info of this site, they aren't to friendly to DIY turbo kits like mine or off the shelf kits that are being sold around the place but they had a heap of good tech that i have used when building my kit and rebuilding my engine for it.
http://www.rbracing-rsr.com/harleyturbos.htm
i have a couple of pics if i can sort out getting them up here, of if i can email them to someone they might get up sooner.
Tim
Tim
Congratulations on your "intestinal fortitude" to pursue your dream and see this through. I think you are always going to have problems with this, but people use to call me crazy too. I had this bad habit of attempting the impossible just because somebody told me it was impossible. I have "mellowed out" a bit over the years and don't run as close to the edge as I used to. If you enjoy riding alone because nobody else can keep up with you and then spend the other half of your spare time working on this gizmo....more power to you. I say...to each his own and I wish you luck!
Aerocharger had one for earlier model Harleys, but take my word for it....unless Aerocharger has came a long way in refining the Harley kits, don't waste your time. I was tickled-pink the day I got mine, became less enchanted as I tried to make it function properly, became more aggravated at the constant rattling from the varibale vanes and was extremely thrilled to death when I sold it for half of what I paid for it.
Maybe that is why they don't have one ready (as per Drago's remarks above).....yet, they have tried it before.
If you are looking for a turbo for a v-rod I sell the kits from RCC turbos. 160/170 hp stock vrod with turbo.
Here is a link to there web site with a pic.
http://www.rccturbos.com/client-bikes/135-ljs-v-rod
Thanks for all the replys guys. Ive actually went in a WHOLE new direction with my turbo project. Im still turbocharging a Harley its just my little toy instead of my big bike. I have a 2005 Buell Blast. Its a single cylinder 500cc engine. Basically a sportster with the back cylinder cut off.
Doing a little more than the turbo though. I took the engine out and starting building a custom no downtube frame for it. Its gonna be a sort of board track racer style. Hoping for 80HP out of the little thumper. Ought to be a fun little bike. Man, I love owning my own motorcycle shop!!!
