Specs & Prices on 05 Dyna Bikes
2005 HARLEY-DAVIDSON Motorcycles
Dyna Glide
Super Glide FXD/FXDI
Official Factory WebSite:
Harley-Davidson Motorcycles
Base MSRP $11,995
DIMENSIONS
Length 91.0 in. Seat Height Laden(1) 26.5 in.
Ground Clearance 5.4 in.
Rake Steering Head/Trail 28.0º / 4.1 in.
Wheelbase 62.5 in. Fuel Capacity(2) 4.8 gals.
Oil Capacity 3.0 qts.
Weight Dry Weight 622.0 lbs.
POWERTRAIN Engine(3) Twin Cam 88®
Displacement 88.0 in.³ Bore x Stroke 3.75 in. x 4.00 in.
Engine
Torque(4)(5) 85.0 ft. lbs. @ 3000 rpm
Fuel System(6) Carburetor or Electronic Sequential Port Fuel Injection (ESPFI )
Compression Ratio 8.9:1
Miles per Gallon(7) Carb. 50 hwy / 42 city ESPFI 50 hwy / 44 city
Primary Drive Chain
Gear Ratio (overall) 1st 10.110 2nd 6.958 3rd 4.953 4th 3.862 5th 3.150
WHEELS/TIRES
Wheels(8) Front Silver 13 spoke cast aluminum alloy Rear Silver 13 spoke cast aluminum alloy
Tire Size Front 100/90-19 57H Rear 150/80B16 71H
ELECTRICAL
Electronics Optional security system
Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout Indicator
Lamps Oil pressure; engine diagnostics
CHASSIS
Brakes (diameter x width) Front 11.5 in. x 0.20 in. Rear 11.5 in. x 0.23 in.
Lean Angle (per SAEJ1168) 32º / 31º
Exhaust System Staggered shorty duals
COLOR OPTIONS(9)
Vivid black, brilliant silver pearl, sierra red pearl, chopper blue pearl
UNIQUE FEATURES
Silver powder-coated engine and polished covers; two-up seating; top-mounted speedometer; nimble handling
Dyna Glide
Super Glide Sport FXDSI
Base MSRP $14,195
DIMENSIONS
Length 91.4 in. Seat Height Laden(1) 27.3 in.
Ground Clearance 5.9 in.
Wheelbase 63.2 in.
Fuel Capacity(2) 4.8 gals. Oil Capacity 3.0 qts.
Weight Dry Weight 632.0 lbs.
POWERTRAIN
Engine Torque(4)(5) 85.0 ft. lbs. @ 3000 rpm
Primary Drive Chain
WHEELS/TIRES
Wheels(8) Front Black 13 spoke cast aluminum alloy Rear Black 13 spoke cast aluminum alloy Tire Size Front 100/90-19 57H Rear 150/80B16 71H
ELECTRICAL
Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout; tachometer
Indicator Lamps Oil pressure; engine diagnostics
CHASSIS
Brakes (diameter x width) Front 11.5 in. x 0.20 in. dual Rear 11.5 in. x 0.23 in.
Lean Angle (per SAEJ1168) 35º / 34º
COLOR OPTIONS(9)
Vivid black, brilliant silver pearl, smokey gold pearl, black pearl, chopper blue pearl, lava red sunglo, rich sunglo blue
UNIQUE FEATURES
Black-on-black engine and covers; aggressive, low-slung seating; triple disc brakes; premium adjustable sport suspension; top-mounted speedometer and tachometer; nimble handling
Dyna Glide
Super Glide Custom
FXDC/FXDCI
Base MSRP $13,695
DIMENSIONS
POWERTRAIN
Displacement 88.0 in.³ Bore x Stroke 3.75 in. x 4.00 in. Engine Torque(4)(5) 85.0 ft. lbs. @
Dyna Glide
Base MSRP $11,995
DIMENSIONS
Engine
Primary Drive Chain
WHEELS/TIRES
ELECTRICAL
CHASSIS
COLOR OPTIONS(9)
UNIQUE FEATURES
Dyna Glide
Base MSRP $14,195
DIMENSIONS
Wheelbase 63.2 in.
POWERTRAIN
Primary Drive Chain
WHEELS/TIRES
ELECTRICAL
CHASSIS
COLOR OPTIONS(9)
UNIQUE FEATURES
Dyna Glide
Super Glide Custom
FXDC/FXDCI
Base MSRP $13,695
DIMENSIONS
POWERTRAIN
