Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
I'm sure you can make it work, might require slightly different mounts. Check out the "hacked, conversion and trailering" forum here, and the United Sidecar Assciation website http://www.sidecar.com , lots of good information to be found there.
You will mayneed to modify some mounts . Modifying the mounts is something that is commonly done.
But anything will work. If you do your home work and take your time.
