Installing Viking Bags
Ok, so I am throwing this out to the masses who have installed saddle bags and also have the quick release on their Street. I purchased Viking bags for my wifes 2018 Street 750 which also has the quick release rack on it.
While taking out the bolts tonight which hold on the mount pieces for the quick release rack, the portion which is closest to the fender was not an issue, what was an issue was another piece fell out from lord knows where. Its a long black bar, curved with two holes drilled in it. What I am not sure of is: Does this install inside the fender or outside the fender (inside the rear fender mount? I have had thus far major issues installing the saddle bags with the mount pieces. Finding the right size and length of bolt is not easy for sure. Cheers Wayne |
I have had mine apart several times. I think the piece you are talking about goes between the fender and the bar that the bolts go through.
Pics would be nice (visual) & didn't the bags come w/installation instructions? My Ends Cuoio bags came all tha way from Italy and came w/detailed instructions...in English. :D
The black Bar you found came from behind the Black trim that runs along the edge. If it still gives you fits let mine know I will pull mine and take more pictures of it for you. Bolt ACE Hardware/ Fleet farm.
[url=https://flic.kr/p/VL2h4e]https://farm5.staticflickr.com/4269/...c7e70b3b_z.jpg This shows riders right side flip left side as the instruction show. [url=https://flic.kr/p/VYEzUd]https://farm5.staticflickr.com/4279/...7d130315_z.jpg |
https://cimg9.ibsrv.net/gimg/www.hdf...4719a962a7.jpg
https://cimg3.ibsrv.net/gimg/www.hdf...058091d2d2.jpg The one I am talking about is the thin one, top of first picture, right on the second picture. I found it is quite solid, fits in but is not a super fit for sure. Nice bags by the way, almost the same ones. Did you use the bolts provided and then nut on the inside of the fender?. If they worked then I will get longer ones as her Street has the docking station put on by Harley, which are a different threat bolt. So does one put these two black pieces together, then install to the fender? |
Thanks
(Post 17512555)
https://www.flickr.com/photos/144658...57682788938530 [url=https://flic.kr/p/VL2h4e]https://farm5.staticflickr.com/4269/...c7e70b3b_z.jpg This shows riders right side flip left side as the instruction show. [url=https://flic.kr/p/VYEzUd]https://farm5.staticflickr.com/4279/...7d130315_z.jpg Did you reverse the rack to get it that close? |
Originally Posted by CanuckEH
(Post 17513613)
Actually they are the same bags, Looks great
Did you reverse the rack to get it that close? Yes the thin one goes in side the the large one. The rear raised nipple you see on the thin one goes toward the bike. The bags have help up well over a year in a good bit of rain and snow. Mounts flipped I had to drill the lower holes to fit the silly bolts they had were just to small. It was really easy. [url=https://flic.kr/p/27MJUb2]https://farm2.staticflickr.com/1828/...6338e507_z.jpg I purchased the Street 750 just because, It has turned out to be a Blast [url=https://flic.kr/p/CVeHHV]https://farm5.staticflickr.com/4638/...ee979d91_z.jpg |
The issue I seem to be having is the 2018 Street 750 does not have anyplace to put nuts on. The bolts that hold the fender on go into a solid piece welded to the frame. My understanding is the order is inside fender, the long black spacer piece, then fender, then the outside piece that fits over the spring. As for the saddle bags, I have to go out and get the same size width of bolt that Harley put on when they installed the quick release however longer of course.
so it would basically be bag, holder reversed, quick release, fender piece, fender, fender strap then into the frame which a bolt screws into. https://cimg8.ibsrv.net/gimg/www.hdf...fc50da0be8.jpg https://cimg9.ibsrv.net/gimg/www.hdf...501da7ae8d.jpg |
Looks like you stripped them. Only one option get new long bolts and tap them. yes you need longer bolts . And the ones that came with it are too small.
Thank you for all your help Smitty. After much cursing, my wife took the bike to Good Times cycle here in Ottawa where even the tech had a headache. No issue retaping the threads, what was a pain in the ass was putting it all through the quick release hardware and that retarded fender spacer. My wife will be constantly checking the bolts as they had to be quite long, however it's on, straight with the quick release hardware/rack. Was not a fun issue for sure. I do not believe Vikings made these with the 2018 Street with quick release hardware regardless of longer bolts and larger size bolts. Any time you take a loc tited bolt out that Harley put it, nothing it seems to quite go back straight. LOL. However done now and does look good.
Cheers |
© 2024 MH Sub I, LLC dba Internet Brands
