Bike runs for 30 to 40 seconds and then shuts off
Hey guys
I have a 2017 HD xg750a streetrod. It was paked for a bit and when I went to start the bike it just clicked clicked like the battery was flat. Took the battery out and fully charged it and put it back on the bike ( accessories connected ) and it started up and ran for 20 to 30 seconds and shutoff Thinking it was a bad batyery i went and picked up a new one today. Put it in ...bike fired right up... ran for 20 to 40 seonds and shut off Noticed the check engine light was on so i brought up the codes ECM Y SPEDO N P2300 - problem with the primary or secondary control circuit in ignition coil A P2303 - primary circuit has failed and most likely will result in a no start or stall of the engine since this is a second coil in a two coil engine. P0691 - powertrain control module (PCM) has detected an inappropriate level of voltage in the electric cooling fan's control circuit. Cleared the codes and the bike does the same thing as mentioned above? Any help ? |
Check and clean any connections. Pull plugs engine cold clean install. Check plug wires try again. You maybe looking at bad coils
(Post 21317780)
Strips removed marked in red on photo https://cimg3.ibsrv.net/gimg/www.hdf...751dff97ad.jpg |
This may sound silly. But pull the main fuse let bike sit a minute and try again.
Any other factors to consider...upgrades/tuner...??
Sounds like a fuel check valve issue.
If it was carbed, I'd say the float was sticking. |
Sounds like a fuel problem to me too.
On a 2017 not going to be carbs. |
Originally Posted by Iceman24
(Post 21318022)
Originally Posted by vonh12
(Post 21318154)
On a 2017 not going to be carbs. Fuel pump, collapsing hose or clogged pick-up screen? Ethanol wreaks havoc on rubber, breaks the hose down inside and you can't see it. Decina grates inside and clogs small passages. |
Originally Posted by RANGER73
(Post 21318317)
I know, that's why I said "IF" it was carbed.
Fuel pump, collapsing hose or clogged pick-up screen? Ethanol wreaks havoc on rubber, breaks the hose down inside and you can't see it. Decina grates inside and clogs small passages. The Street engine is a different animal in the zoo. |
© 2024 MH Sub I, LLC dba Internet Brands
