Validate tune, eliminate need for dyno tuning
#31
Have you considered ditching the PC and getting a flash tuner that will allow complete tuning as well as allowing data logging? Personally, I prefer the TTS but Power Vision is powerful as well and with it you can watch parameters as you ride.
I feel you would be much better off in the long run. Just something to consider if you haven’t already done so.
#32
#33
the PCV and 2 channel auto tune kit is available for your bike, PCV (better and smaller than pc3) and the 2 O2 sensors to go in the pipe, you can use it to build good fuel tables, then unplug the auto tune box and hook the sensors up to real time guages. once the sensors are in the pipes, it gets pretty easy to switch back and forth. if you had that stuff, you could then begin to experiment with the timing, that is until you take it in.
m
m
#34
ehh... no worries.
the PCV and the thundermax are both available for my bike, those with auto-tune capabilities for $900. I thought about getting the thundermax, because I don't like the idea piggybacks, but I can essentially do the same thing with a good set of gauges and data logging for maybe $400, $500 less and since I already have a tuner I'm leaning that way. I read somewhere that the PC3 has some issues with Idol that are corrected in the PC 5 which is also of Interest
m
m
#35
I settled on Innovative Motorsports products. Total cost is about $500, which is nearly half of what it would cost for a PCV with Auto Tune. SInce I already have a PCIII, this should be the ticket to success.
I'l mount the gauge in my fairing where the Air Temperate gaauge currently sits. I'll have to install o2 bungs in my Thunderhead headers. This system will give me the ability to view real-time AFR data on my gauge, and to log it in their data logger along with RPM data. I'll also be able to install CHT logging and gauge in the future, if I decide to. I should be able to capture Alpha-N as well.
With this setup, I'll be able to validate the quality of my existing tune, and eliminate the need to take this bike back to the tuner for mixture tunes. I still might take it back for timing tune though.
Thanks to everyone who has helped me sort this out! I appreciate it more than you know.
DLG-1: Dual Lambda (AFR) Gauge Kit - includes the DLG-1 gauge, (2) Wideband Bosch LSU4.9 O2 sensors, (2) 8 ft sensor cables, LC-2 Wideband Controller, (2) O2 sensor weld-on bungs, Black/Silver bezel, Black/White faceplate, Serial program cable, & Installation manual. P/N: 3891
SSI-4 PLUS Four Channel Sensor Interface includes the SSI-4 PLUS, Serial Program Cable, Molex to Molex Patch Cable (to daisy chain with other MTS compatible devices), and manual. P/N 3914
Pocket Logger PL-1 Kit
Kit includes:
PL-1, Pocket Logger
LogWorks Software
Kit includes:
PL-1, Pocket Logger
- 2GB SD Memory Card
- SD Memory Card Reader, USB to PC
- Power Cable, 12v
- LogWorks 3.0 Software, available for download
- MTS Patch Cable, Locking 4-pin to 4-pin, for newer devices like the MTX gauges
- MTS Patch Cable, 2.5mm to 4-pin, needed for LC-1, SSI-4, TC-4, & LMA-3
LogWorks Software
#36
#37
Thanks. I'm aware of those limitations but I don't want to drop a ton of money on this. This setup will allow me to properly tune my engine without having to pay a tuner for dyno work. That's all I need.
#38
#39
I've since learned that Thundermax makes a replacement ECM for my bike that would likely work very well. I'f I cant find a data logger that will track RPM, AFR, and TPS - which, as I understand it, works by varying the resistance of a signal rather than the voltage - then I will go with the thundermax. In a holding pattern for now.
#40
Got the headpipe back from the welder, where I had stainless angled bungs installed for Bosch wide band O2 sensors. Also installed the AFR gauge in the dash, in place of the air temp gauge.
Once mixture is validated / dialed in, I'll street tune the timing and continue with break-in per S & S instructions.
