Need map for PCIII for my mods....
I am looking for a map that would be good until I can get my bike to the dyno to make a custom map. I have a 06 softail nighttrain, put the big bore cylinders, 10.5:1 high compression pistons, 211 cams, have SE air cleaner, and V&H sideshots. If anyone knows what map would work the closest and best for this set up till I can make my own I would appreciate it.
RE: Need map for PCIII for my mods....
M805-099
Khrome Werks full exhaust, 95 inch Stage 2 big bore kit (flat top pistons), Stage 2 ECU, Screamin Eagle 211 Cams, Screamin Eagle Heads and Screamin Eagle air filter
29 KB
M805-101
Vance & Hines 2:1 Pro Pipe, 95 inch Stage 2 big bore kit (flat top pistons), Stage 2 ECU, Screamin Eagle 211 Cams, Screamin Eagle Heads and Screamin Eagle air filter
29 KB
M805-104
Thunderheader full exhaust, 95 inch Stage 2 big bore kit (flat top pistons), Stage 2 ECU, Screamin Eagle 211 Cams, Screamin Eagle Heads and Screamin Eagle air filter
29 KB
M805-106
Cycle Shack tapered slip-ons, 95 inch Stage 2 big bore kit (flat top pistons), Stage 2 ECU, Screamin Eagle 211 Cams, Screamin Eagle Heads and Screamin Eagle air filter
29 KB
M805-107
SuperTrapp 2:1 (21 discs & closed end cap), 95 inch Stage 2 big bore kit (flat top pistons), Stage 2 ECU, Screamin Eagle 211 Cams, Screamin Eagle Heads and Screamin Eagle air filter
29 KB
