Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Ok so just finish a 107 build with beans street port heads and tman standard 555 cams,Je dome pistons. I stuck with the stock intake and will be running dual thunderheader/thundercones. Comp is at or around 10.6/1 and ccp at around 195-200. Can seem to find anything in thundermax program that is close, is there any tuners that would have a map as a baseline?also what kinda of numbers should I expect realistically
When I finished the build on the 110 to 113 with CNC ported heads, cams and raised compression, TMax sent me a close map which I loaded in then let the autotune feature finish the process. Could feel the difference after a few rides.
