96 to 103 map changes
Old Dec 9, 2012 | 05:51 PM
jefftc88's Avatar
jefftc88
6th Gear
Default 96 to 103 map changes
1st thread. I am taking my 08 heritage to a 103. I currently run reaper 525 cams, big shot exhaust rsd breather, the upgrade will include light port and polish on the heads .030 head gasket using stock 103 pistons. Was planning on shaving the heads to get to 9.5 compression. Question will the custom map I,m running now be a good starting point (powercommander3) say plus 10% across the board. Map was a download from feuling website, runs excellent now
should leave it alone but I'm gonna screw with it anyway
Old Dec 10, 2012 | 12:41 AM
oct1949's Avatar
oct1949
May be a starting point, but I'd call Fuel Moto to be sure.
I'd also say U'll for sure need a new map, more so since Ur doing Ur Heads.
U should flow a good increase in Air which will make her really lean.
Old Dec 10, 2012 | 04:25 AM
jefftc88's Avatar
jefftc88
6th Gear
thanks, kinda what I was thinking. power commander came from cyclesolutions last year. Will fuelmoto give tech support even though I bought somewhere else. hadn't heard of them when I purchased pc3
jeff
Old Dec 11, 2012 | 02:45 AM
oct1949's Avatar
oct1949
They might help Ya but thinking for them to actually send U a Map u need to purchase from them..
Don't hurt to call anyway, can't hurt as they can only say No..
Old Dec 11, 2012 | 06:04 AM
Bluehighways's Avatar
Bluehighways
I have a similar build, although my compression ratio is more like 10:1. I used TTS Master Tune and there's not a 10% difference between stock and current programming.
dirtracer27x
May 22, 2019 06:39 AM
jfarrar30
Mar 14, 2013 07:44 PM
olelucky
Apr 11, 2010 08:05 PM
drhooligan
Oct 1, 2008 05:07 PM
RoadK45
Exhaust System Topics
Jun 14, 2008 09:52 PM
