Crank no start
Crank no start
Turning on the key there’s no fuel pump wine, checked fuse and rely. One middle pin was broke off relay. Replaced and still no luck. Checked voltage going to the plug on fuel pump plate and it has 13v going to it. Also no reading on the fuel gauge and “r Lo” on the speedometer. Bike sat for a year & tank was dry. Any advice? 2008 crossbones
yes. Added 3 gallons. Just got the pump out and the back of the plate and everything had a layer of chalk on it from dried fuel I’m guessing. Filter on bottom of pump was also disintegrated. Ohlm reading on pump is 90 with it pulled out. From my research that’s what it should read at half tank?
Wiring diagram here - 99949-08_en - 2008 Wiring Diagrams | Harley-Davidson SIP
If you look at the relays you can see that the normally closed contact is not used. It is not unusual for relays to have that pin missing.
pointdiver
07-05-2015 11:50 AM
MRCParkerJR
05-28-2013 08:35 PM
