erratic high idle
erratic high idle
06 Ultra, since new Idle/low speed problems. 17k. Stage 1, sert, ovals,2 sets of induction seals, Idle air motor,dinoed. After riding till hot, shut off let heat soak for 5/10 min. start and ride for 1 block. Bike will high idle for 10 sec. to 5 minutes. Turn off and restart. problem goes away.When it does that, you can smell raw gas for a few minutes. On occasion, will high idle while riding. Bike only high idles when cold for 3/5 sec. then idles at 950/1000.
RE: erratic high idle
Is it a possibility that I have a leaking injector? It smells of raw gas after a hot heat soak and will high idle for a few minutes. Can I take the air cleaner off and see inside the induction module to see if gas is present??? Or take it in to dealer and have injectors pulled and lay outside of the mfd and turn pump on to pressurize them. I,m desperate to get this thing fixed. thanks Dan
on an 06, its highly unlikely that an injector is leaking......... if that was the case, your plugs would be black and the bike's rpms would drop from a rich condition.
the temp sensor can make the puter think the bike is cold, therefore opening the IAC, rasing the idle and richening the mixture as well since an engine needs more fuel when cold. this would be why you smell gas
I,ve taken that bike back to the dealer so many times, it,s like the little boy crying wolf, they can,t seem to get it to act up on them. I know where the temp. switch is located. Is it pricey to replace on my own?? Or is it something I need to test before I replace it??? Thnaks
Well thad did not work! I changed it out and rode 4 different days at different temps. Whenever you shut it off and heat soak for 5/10 min. it will high idle as before. It will even do it while riding , it will forget to idle down. stays at 1500 to you shut it off and restart it. Help people. The dealer is still sctatching his whatever!!!!! thanks Dan
