How do you retreive 2006 Dyna trouble codes
I just bought a 2006 Dyna Low Rider today and took a 50 mile ride and the engine light came on and stayed on. How do you retreive 2006 Dyna trouble codes?
RE: How do you retreive 2006 Dyna trouble codes
Here you go. ;)
[IMG]local://upfiles/5333/96BD1353900741DBA9AFE417F1B97E1E.jpg[/IMG] |
PowerCobra98,
Thank you. Do you also have a copy of the codes? I ordered the service manuals but they are on back order. |
No, I don't have an electronic copy of them.
You can post your code though and I'll be happy to try and tell you what it means. |
PowerCobra98,
Thank You, I started checking everything on my bike and found loose battery connections and a broken connector under the seat, I corrected those three items and took the bike out for a ride and the engine light didn't come back on. I used the procedure that you posted and found a code in memory P0154 and did a search for that code on this site which turned out to be rear o2 sensor open not responding (the broken connector) Thanks again for the help. |
ORIGINAL: WS6 Formula PowerCobra98, Thank You, I started checking everything on my bike and found loose battery connections and a broken connector under the seat, I corrected those three items and took the bike out for a ride and the engine light didn't come back on. I used the procedure that you posted and found a code in memory P0154 and did a search for that code on this site which turned out to be rear o2 sensor open not responding (the broken connector) Thanks again for the help. |
hi thanks for the literature i need a code cracked p0131 thanks
P0131
O2 Sensor Bank 1 Sensor 1 Low Voltage |
thank you and ive cleared that code how about a p0151 i put a tfi on my bike today so i go for i ride around the block and then the light comes on and shoots out the code but the p0131 only popped up once.also i have some popping on deceleration.
P0151
O2 Sensor Bank 2 Sensor 1 Low Voltage You can find all of these codes online by just typing the code into any Search Engine such as Yahoo, Google, MSN, etc. |
© 2024 MH Sub I, LLC dba Internet Brands
