TTS Mastertune Information
  #4831
Old 03-28-2014, 05:16 PM
FLTpilot's Avatar
FLTpilot
FLTpilot is offline
Originally Posted by Mr. Wizard
No sir... should have set up a VTune calibration, flash that to the bike and set up Flight Recorder for VTune data.
Oops... I have time and will certainly be riding again soon!
Time to RTFM....
Thank you Wizard
  #4832
Old 03-28-2014, 11:25 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
One thing to NOT do, that Docs tuning guide saya to do is this: Do NOT set AE and DE to zero. Leave it as is. Doc had to recant on this one thing later.
With AE and DE set to zero while v-tuning... some odd stuff happens. Turns out setting to zero does NOT turn these functions off, just allows behind the scenes things to change.
Even if you set these to .1, you would be OK, but setting to zero, makes it start to learn upon key on, with the engine not even running.
Have fun tuning, my Jakazz friend!
  #4833
Old 03-29-2014, 08:00 AM
jakazz's Avatar
jakazz
jakazz is offline
So what do you guys recommend stock cal settings or the .1?
I have both set to zero right now
  #4834
Old 03-29-2014, 08:25 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,037 Likes on 1,105 Posts
What truk is saying is not to set the AE and DE to zero on the VTune calibration. You can set it to .1 to keep it from skewing the coding during VTuning your bike. TTS recommends leaving those tables alone when VTuning.
When VTuning, your VTune cal changes are AFR/Lambda to 14.6/.981, Adaptive Knock to Zero and your PE to higher RPM's than the motor will spin. After VTuning you should change all these tables back to original.
In your final calibration you can fine tune your AE and DE settings later if you have throttle lag or decel pop after you VTune.
All that is in the PDF file in my signature.
  #4835
Old 03-29-2014, 08:28 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
TTS for UltraNutz! I mean dummies.. tells you all you need to know.
  #4836
Old 03-29-2014, 08:43 AM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
TTS had an update last night....
It's mainly for the new TTS analyzer (Green Box) but there are software changes that will reflect needed updates for the VT3. Go get it boys...
Try to break it and report back.
  #4837
Old 03-29-2014, 11:42 AM
wurk_truk's Avatar
wurk_truk
Yup. The updates will mainly be for TTS 2.5. 2.5 will not be for the cast majority of TTS users. This small run of TTS will be for tuners, etc to have the ability to hook up off board devices and have that information show up as just another trace in datamaster. Good Stuff!
This was included because of VTune 3 is coming at some point. Before they move forward with #3... #2.5 has to work so this all gets integrated together.
This is going to be interesting.
  #4838
Old 03-29-2014, 11:52 AM
wurk_truk's Avatar
wurk_truk
I recommend you guys just leave AE and DE alone until all the way done with v-tuning. AFter v-tuning, AE will play a big role in stumble, etc.
Leaving AE and DE alone simply means the bike will take a few more moments to fill certain cells. When AE or DE is active, while v-tuning, the v-tune process will stop gathering data for that small moment of time.
The issue, when turning this off is this: when in zero state, the ECU will collect data when the engine is turned off but the key is on. It surprised all of us, when this was discovered. It's easy to figure out, a non running engine will surely have different data than one that is running.
The purpose of posting information here on HDF is to get my members to use this tool to the best of its abilities. I have talked to Wiz, naturally, and we both agree we REALLY like the members, here on HDF.
Feel FREE to ask ANY question... there is no such thing as a dumb question. We are here to help.
  #4839
Old 03-29-2014, 12:03 PM
lp7734's Avatar
lp7734
lp7734 is offline
5th Gear
Default o2 sensor confusion
Ok I am new at this but want to learn and know what I am doing and why. As I was reviewing my datamaster runs I noticed that the o2 sensor voltage was running from 980 mv to 1700mv+ but according to the o2 calculator for a lambda of .981 it should have been 785mv So what did I do wrong...Is this normal when you set up to doing vtuning? setting main lambda to .981 ect. Thank you all in advance for your time and answers.
  #4840
Old 03-29-2014, 05:48 PM
wurk_truk's Avatar
wurk_truk
Where in Ohio are you located?
Quick Reply: TTS Mastertune Information
