SEPST MAP 2009 Ultra
Hello all
Can anyone help me? I have a 2009 ultra with Hooker Pipes, SE A/C. high flow heads, SE 103 Kit and Andrews 37H Cams. I have used sepst map# 205UH004. this map covers everything other than the andrews cam. The cams mentioned in the catalogue are the SE 255. I am flat spotting at about 3250 to 3500. Does anyone have a better map or idea?
Dave
Dave
I would get the 2010 SE parts catalog, check the 255 cam specs vs your 37H cams, and try to match it to the closest SE cam. Then, cross check in the list of programs in the SEPST calibrations to see if you can select a better matching program with SE cam. If there is one, then you can always open tables within the calibration you currently have and compare to the newly found one to see how different the two are.
You may be able to increase the VE in the upper RPM range where the 37 cams exceed the 255s and make slight changes that way. Just a thought.
Good luck...
Good luck...
Hello all
Dave
Dave
I have just started messing with it still a lot to learn.
