base map question
Is there a difference between the standard flash you can get with just adding slip ons vs the canned base map you can get if you have a SERT?
Just to add to my knowledge, thanks |
if you're adding slipons only, there is no need to adjust the base "stock" map. if you're adding pipes and high flow breather at the same time then you must have at a minimum of a stage 1 flash done.
If you add just high flow breather, it is recommended to do the stage 1 flash as well. As far as whether there is a difference between a stage 1 map and the canned map that comes with the SERT, I'm certain there are but you'll have to open both maps up and look to see the differences. jluvs2ride (expert with the sert and sespt devices) might be able to answer off the top of his head... |
Originally Posted by arcticrider
(Post 7786207)
© 2024 MH Sub I, LLC dba Internet Brands
