SEPro/SEStreet Tuner Information Thread
Old 04-09-2018, 11:45 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
Originally Posted by bbflhxs
So I just had the stage 4 kit installed on my 2018 flhxs. I’m running thunder header slip ons, which i am happy with, but I’d like to do a cat delete with a jackpot 2 1 2 header or something similar. My question is am I able to run a full exhaust without a cat while using the S.E. pro street tuner?
You mean, can you use the SE Pro Street Tuner to give an acceptable tune to your bike, with a non-Harley-Davidson exhaust system, with no catalytic converters?
No.
  #3462
Old 04-10-2018, 11:31 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
You’re ok until you remove the cat. Thundercones are a bit too free flowing for best results without the cat.
Once you remove the cat the Street Tuner calibration will not allow enough fuel to compensate for the wide open exhaust.
Bob
  #3463
Old 05-23-2018, 10:57 PM
DynaDaego's Avatar
DynaDaego
DynaDaego is offline
Hoping someone can recommend the best map for me. Using SEPro on 2014 Dyna. Stage 1 Harley filter and Python dual staggered pipes (basically VH Bigshots). All I am seeing is the basic stage one map option in my software and that seems conservative to me. Like there should be a next step up for the free flow pipes between the Stage 2. Any advice?
  #3464
Old 05-23-2018, 11:57 PM
jkhawaii's Avatar
jkhawaii
jkhawaii is offline
how about coping the map from the V&H FP3? Download the FP3 software, demo mode, copy the map.
  #3465
Old 05-24-2018, 03:25 PM
DynaDaego's Avatar
DynaDaego
Thats a cool idea. Think results will be better than doing the record option and importing saved live data so Pro Tuner does whatever it does?
  #3466
Old 05-24-2018, 03:54 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Thats a cool idea.. Think results will be better than doing the record option and importing saved live data so Pro Tuner does whatever it does?
There is no substitute for a well tuned bike. If you were to do a few SmartTunes your bike will run smoother, more responsive, and great mileage to boot!
Anything less is WAG assuming everything in the EFI is the same from bike to bike. Fuel injectors alone have a +/- 10+% output variance from spec’d values.
Anything mfg’d has production variances which require recalibration to get the best performance from any airflow changes such as exhaust, intake, cams, porting, etc.
HTH,
Bob
  #3467
Old 05-24-2018, 06:15 PM
DynaDaego's Avatar
DynaDaego
Unfortunately that approach isn't working out. It doesn't offer any laptop download options I can find and wants a ton of personal device info for me to access the google play store. Pretty lame.
  #3468
Old 05-28-2018, 08:07 PM
NeedlesMN's Avatar
NeedlesMN
NeedlesMN is offline
Stage II
Hi there – first post on the forum and was looking for some guidance in using the SESTP with my 2017 Roadster.
I've just installed the V&E Short shot exhaust system, with the SE Heavy Breather intake. There's no exact default map for this configuration, so I went with the basic Stage 1 option and SmartTune. The bike is running very lean, with lots of decel popping, even after I flashed the ECM with 3-4 Smart Tune recordings. I can tell when I'm riding that the engine just isn't getting enough fuel.
In evaluating the VE Tables in more detail, I noticed that the numbers for the Smart Tune VE tables never exactly match the Working VE tables, after I've updated them. In fact, when I've tried to increase some of the VE values in the Working tables, the application won't let me. For example, the Smart Tune VE Rear table shows a value of 73.3 at 1000 RPM at 0 Throttle. That same box is red in my Working VE Rear table with a value of 66.0, and when I update, it stays the same - 66.0. It doesn't turn turquoise and it won't allow me to manually increase the value. This is true of all the values in red on my "Working" VE Rear Table.
Is this a software limitation, in terms of how much I'm allowed to increase the VE Table values, or am I doing something wrong? Any advice would be appreciated!
  #3469
Old 05-29-2018, 04:05 AM
modular's Avatar
modular
modular is offline
Can the end user of the SEPST bump up the rev limiter? I've seen dyno results showing 6250RPM's.
  #3470
Old 05-29-2018, 12:26 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Sorry but the Street tuner is handcuffed to EPA emissions regs so if you change ANYTHING (by p/n) from the formula as set out by the approved stage kit, the results cannot be assumed to be attainable with that tool.
That said, a couple proper smart tunes should get he bike to run ok, maybe not the best but ok for sure.
Bob
Quick Reply: SEPro/SEStreet Tuner Information Thread
