Power Vision Information Thread
#9101
LoneRiderFLH (08-19-2018)
#9102
Live Idle is not an active feature on the M8 bikes, however you can adjust the idle speed in your calibration in the WinPv software under Airflow>Idle RPM. If it is not showing as an active tune item you will need to simply update your tune. Make sure you have the latest firmware & tune database in your PV device and plug it in via USB, open your calibration, from the upper drop down menu select PowerVision>Update tune using PV and it will update your tune with the latest tables.
#9103
If you asking about in the WinPV software, yes.
under the Setup menu , choose options, then click on "Units", you should see a drop down indicator that allows you to change between Imperial (F) and Metric (C).
#9104
#9105
If you open the table, there is "Delta" menu selection on the right side of the window (or under the compare menu) to show the differences.
#9107
Fuel map or something else??
[Originally posted this in the Dyna section, hope for additional thoughts here]
Bike had a D&D Fat Cat exhaust w/ Louvered Baffles, SE Heavy Breather intake, and oil cooler with the stock cams. PV typically reported temps of 265-268 degrees unless stuck idling in traffic in the Texas summer, then it could go as high as 304 degrees. But would cool quickly once moving again.
Now with an upgrade to Andrews 57H cams and a new tune from Fuel Moto (plus 1 autotune session), my bike is running at 285 degrees on open interstate highway, and up to 313 degrees on slower neighborhood streets, haven't even tried it stuck idling in traffic. Today's 200-mile trip did show an improvement of over 1 mpg (for what that's worth). Bike also pulls and sounds better.
I have emailed a map modification request to Fuel Moto that they should find in their inbox on Monday. I had thought that the autotune session might clean up the heat issue - I thought wrong. Hope there is an easy fix and that it's not another issue (like the engine sumping??).
#9108
#9109
They phased that out like 4 years ago. I can't vouch for this website at all, so enter at your own risk. It claims to have the program available for download. If you contract a PC virus don't yell at me. LOL
https://power-vision-log-tuner.software.informer.com/
#9110
2018 Fat Bob, 0 miles, TT & PV compliments of FM.
TT & PV ready for 1st tune upload that FM sent for my bike’s set up although the only map they had that came close to my bike’s set up had the HD 447 Torque Cam and not the HD 462 Power Cam I have installed. They said I’d have to “Fine Tune” their tune. Would anyone know where I’d start to fine tune their tune? Would I just start an Auto Tune session & refine the AT sessions from there?
Also looking through some Dyno Jet Youtubes I found this vid
. that references the PV “Quick Tune” screen(s):
“Configuration Tab” to turn ON or OFF:
1.) ACR
2.) Heated 02 Sensors
“Tweaks Tab” to turn ON or OFF:
1.) Adaptive
Any suggestions whether to turn ON or OFF the above Quick Tunes? Thanks
1.) ACR
1.) Adaptive
